The continuity test is slow on the UT71, but it is latched.
The meter has a fast display mode when it is required, with a count of 4,000 instead of 40,000. It is activated at start-up.
You are the first person I hear from, who complains about display contrast, when the meter has one of the best displays in the business. Too late now I guess, but a new battery would probably have fixed your problem.
The built quality is reasonable, as a 40,000 count bench meter. I wouldn't dare throw it in a toolbox though, like some people do with their Flukes.
Take the meter completely apart and look for some visual damage on all components. If the main IC is toast, contact Cyrustek for a replacement.
Good luck finding another meter with the same features, for a reasonable price.
Hi there and thank you for the reply.
I apreciate that you like the multimeter this much, but I also bought it because of my likes on the specs and good comented on it. If I wanted a 4000 counts multimeter I would buy a good 6000 count one at that price range and not this one, but I wanted to have a 60000 count one and this ut71d was all I could buy at that time. I wanted to buy the Fluke 87 but ended buying ut71d.
When the multimeter sits on a normal bench and you read the display there are strange rays from center down of display cover to up and you can not read good on the display. At first i got used to the ideea but in time it gets anoying. Your picture shows the display with backlight on and in not what the display looks like in daylight or workshop ceiling light, unless you work in the dark. I was forcet to place it closer to me, and when you have a big pcb to measure components on viewing the display will be harder. The multimeter feels solid in the hand but I didn`t put it in my toolbox without his textile bag.
The battery was not an issue as it was replaced, the display indicated that with low bat sign a while ago.
A major factors in buying this unit, if i remember corectly, was the 0.01 resolution on the resistor scale, overall accuracy, pc software and i hoped that everything else will be just as good. Any way i am looking for a new multimeter now and the fact that i killed it has nothing to do with it.
There are no visible defective parts on the pcb, the only thing i suspect broken is the first chip that receive input signal from probes. In the mean time i am looking to buy, as you said a resonable priced multimeter with similar features, good overall accuracy, maybe less features but the ones it will have will be the ones i use most.
Regards, Leo
