Hey guys,
I god a brand new problem using my Fluke 79 III TRMS DMM measuring the resistance!
When I switched it to low ohms resistance range, everything was ok.
But today at 4 pm,, I switched it to high resistance range and as I tested it by shorting out the terminals with the red measuring line I got the following result:
The screen blinks and the measurement value is at least negative
What's going wrong here? I've never seen such a behaviour before, nut at a Fluke nor any other DMM I own.
Please have a look:
https://www.youtube.com/watch?v=rcMxsW_HsRE&feature=youtu.beWhat happend? After some hours, the Fluke healed itself and still works fine until now.
Is it out of cal so that the measurement of high resistance maybe went down unter 0 Volts in the measurement circuit or what's the deal?
I couldn't find any dependencies on moisture or temperature or something like that.
Any ideas?
Thanx a lot from germany,
Matthias
