Author Topic: Anyone who bought a Rigol DG4062 wish they would have bought a DG4102 or DG4162?  (Read 20192 times)
Offline boeserbaer
While this is a bit stale,
I recently bought a dg4062.  Perfectly happy with it.  It is unrestricted as a 500MSPS AWG.  The sine wave limits of 60MHz are very acceptable to me.
Best Regards,  Mike
Offline Electro FanTopic starter
Best Regards,  Mike
Hi boeserbaer,
Any chance you could do the test AndyC_772 did in Reply 2 of this thread to see if you get the same results?  (Maybe you have newer firmware or something is different now?)
https://www.eevblog.com/forum/testgear/anyone-who-bought-a-rigol-dg4062-wish-they-would-have-bought-a-dg4102-or-dg4162/msg292628/#msg292628
Thanks, EF
« Last Edit: December 04, 2014, 06:30:17 pm by Electro Fan »
Offline csatti
  • Country: hu
I have a DG4062 and I had run this test for you (I was also wondering if it is really that bad). I had a much better result (the leading and trailing can't be shorter than 11ns it seems).
Offline Teneyes
For fast rise and fall times , I use the DG4062 sync output
IiIiIiIiIi  --  curiosity killed the cat but, satisfaction brought it back
