Thanks, I've had a look at those devices. I can't find info on my use case in the corresponding datasheets, so I think i need to give a few more info on my use case
We're designing a product with bus communication interface. This usually outputs low voltage (16V), but needs to be tolerant when the electrician erroneously connects 230V AC to the bus terminals. For this, we've included a circuit that detects the voltage and isolates the bus. This happens within something like 1
µs, where the worst case is applying the voltage at AC peak. This circuit now needs to be checked for switching time / failure current / destruction parameters, where only say 10µs after switching on is relevant. We've done some testing with just an isolation transformer and a switch, trying to hit the AC peak.
With that
- one needs many tries until successful
- we have switch bouncing
- we can see that the major current limiting element is the transformer internal resistance
- we can't set the internal resistance to a defined value (at least not reduce...)
- safety problems
We're now at the point that our time scale is so short that we don't need AC voltage at all, which finally brings me to the opening question:
We thought about making a box with a "high" voltage capacitor, charging / discharging series resistors and test switch.
But, does a tester like this, maybe a bit more sophisticated, exist as from-the-shelf unit?
