I have thirteen P6139A probes, nine of them purchased used. In purchasing the used ones, I encountered two that had internal shorts, possibly from the whisker issue that KE5FX mentions. The resistance on both indicated the short was at the probe end, so it could have also been the tip cartridge and not the cable; I don't know. They were returned to the seller for a refund without further investigation.
At any rate, that was 5 years ago, and the nine I kept are still working fine. The other four I bought new 25 years ago, and they are fine too.
So... I think the P6139A is ok to buy as long as you have a return option. I would also try to get ones with as many accessories as possible (ground clip, sprung hook, color rings, etc. - see the manual) as genuine accessories can get expensive to buy individually.
