Well, they look like 'honest' scopes - what you see is what you get. Very clear front panel layout.
From what I can see, on the plus side you have:
- Decent maximum input levels
- Calibrated V/Div and Time/Div controls
- Very simple layout
- X-Y mode
- Reasonable range of triggering options, including ext.
On the negative side (obvious really):
- Single chanel
- No dual / delayed timebase
- I'm not keen on the round CRT on the top one, although scopes were made like that for years.
If single channel, single timebase is sufficient for your audio-only work then those aren't a problem.
There's no way to comment on value for money as you haven't given a price, but I suspect that was intentional. As I say, it's very much a what you see is what you get product.
P.S. I just noticed your real user comment - I doubt if you'll find many actual users of these particular model scopes, I've never seen them before or heard of the brand name. I don't know your location or which countries they are sold in.
P.P.S. The circuitry looks really simple, you ought to be able to maintain it indefinitely apart from maybe CRT, HT transformer any manufacturer specific switches etc.
These have been around for years--"badge engineered" as Attens,Digitech,& a host of other names.
I bought the "Digitech" one ("portrait" style) quite a few years back,to help me fix my BWD 511.
I found the BWD fault with it,but never finished fixing that instrument,as the little "crudscope", as I nicknamed it, did most of the same stuff---the screen size is tiny compared with the BWD,butI could live with it.
I paid more than I should for it--$A135!!,but didn't have the time to chase around at the time.
It has definite "pros & cons".
Pros:-
(1)Trigger circuit works well.
(2) Timebase range is good
(3) Display vertical linearity is good (easy enough with such a small CRT).
(4) External trigger input
(5) X-Y inputs
(6)TV "H " & "V" syngh position(not all that useful these days)
(7)"Line "trigger position ( triggers off Mains 50 or 60 Hz)
Cons:-
(1) Tiny screen, unilluminated graticule with fairly poor marking.
(2) Knobs fall off
(3) BNC vert connector has too short threaded part,so it comes loose--replace with good connector.
(4) The tube EHT circuit failed in mine--easy to fix,just replace the switching transistors.
(5) The thing is tiny--it looks like it was designed to be operated by "Cabbage Patch Kids".
As I have said on many occasions,you can do good work with the most basic Oscilloscope.
It came in very handy in tracing control circuits of a UHF transmitter in my last job before retirement.
( they had a Spec An but no 'scope!!!)
A few years back,I bought a Tek 7613 at a Hamfest----40 years old,but compared to the Digitech,it was like comparing a Learjet to a hanglider!
It cost me the same amount I had paid for the "crudscope" a few years before.
That said,I've got a "soft spot" for the wee beastie--if it was $A70 to $80 it would be worth buying one--at least it doesn't lie to you like the "El Cheapo" DSOs.
