I just got my YR1035+ battery tester today. Seems to work fine. I primarily got it for measuring LiIon batteries but it seems it makes for a competent milliohm meter in general. I tried to use it for short finding and it can reliably find the shorted component between a number of parallel resistors. There are apparently some more advanced options and features but I can't really find a good manual. They all seem to be poorly translated and there are some differences between units. I assume mine is a clone since the 'YAOREA' name is absent from the front panel. Says version 2.2206 on startup.
Specifically, I'd be interested in the following:
- In one of the manuals I've found it says holding the HOLD key activates relative measurement. My unit doesn't seem to do that?
- I've seen some pictures with 'ZR' displayed under the measurement range indicators and some AE descriptions referencing 'ZR mode' and having it enabled by default. What is it and how do I turn it on?
- Menu option 7 & 8, calibration & factory reset seem to be disabled on my unit? I've read that some manufacturers do that. I don't think my unit needs calibration right now, but is there anything I can do to re-enable those?
- Menu option 9 has a sub-menu with two options 'BU' (set to 'OFF') and 'CR' (set to '7'). What are those?
- How safe is it to use this as a milliohm meter in a circuit? Like, what kind of voltage / current ranges am I exposing the circuit to?
Please let me know if you can answer any of these questions or have a better manual etc., thanks!
