Author Topic: Any experience with Sourcetronics ST1941 Bench Multimeter?  (Read 1136 times)
Offline Zx SpectrumTopic starter
« on: September 27, 2022, 07:35:53 pm »
I am looking for a bech multimeter in the range of 300-400 usd.
I really don't want used units.
eventually my choices boiled down to one of those new chineese brands like UNI-T  or VICI (which I really not interested in) Or BK Precision.
but then I came across Sourcetronics ST1941.
what do thing about ST1941? any experience?
thanks you
Re: Any experience with Sourcetronics ST1941 Bench Multimeter?
« Reply #1 on: September 27, 2022, 07:44:43 pm »
SDM3045X or SDM3055 too much $ ?
« Reply #2 on: September 27, 2022, 07:55:06 pm »
for some reason I ma more attracted to old-style DMMs
Offline coromonadalix
« Reply #3 on: September 27, 2022, 08:52:08 pm »
hum   totally looks / like some BK  units     for sure it's a rebranded unit ???
EDIT
BK Precision 5491B ....   or  this one too is rebranded  lolll
or
BK Precision 2831E
« Last Edit: September 27, 2022, 08:54:38 pm by coromonadalix »
« Reply #4 on: September 27, 2022, 09:38:53 pm »
EDIT
or
BK Precision 2831E
What product lines are they actually OEM for ?
Most of their scopes are Siglent rebrands.
Online Martin72
  • Testfield Technician
« Reply #5 on: September 27, 2022, 10:06:32 pm »
For some products on alibaba for example, when you order a minimum amount of, you can tell them what name will be on it...
Sourcetronic or Abracadabra or Gollum was here...It´s always the same source.
(Kierkegaard)
« Reply #6 on: September 28, 2022, 05:30:17 pm »
so do you think that ST1941 is made by BK precision.
doesn't that mean the ST1941 must be of the same quality as BK precession?
Online Kleinstein
« Reply #7 on: September 28, 2022, 06:04:45 pm »
The BK2831 and ST1941 look very much the same from both the pictures and description.  So they seem to come from the same factory - this may be BK or another unknown OEM.
I would expect essentially the same quality, maybe with slight difference in the calibration and warranty.
The price may vary a bit, depending on the shource. In current times a relevant point may be if it is available at all.
Online Martin72
« Reply #8 on: September 28, 2022, 06:30:07 pm »
No, not at all.
It isn´t so that this meter for example is half as cheap as sourcetronic want to have it with their name on.
But it could be that this meter isn´t build by sourcetronic itself.
Or by BK.
(Kierkegaard)
Offline dzseki
  • Country: hu
« Reply #9 on: September 29, 2022, 10:23:03 am »
I think Sourcetronics is rebranding the Tonghui brand, so much they barely change the model number ST vs. TH.
https://www.tonghui.com.cn/en/product_list_158.html
For sure Sourcetronics wants to appear as an european brand, while Tonghui, well everyone knows... But based on the little information available on Tonghui instruments they are fairly well built.
HP 1720A scope with HP 1120A probe, EMG 12563 pulse generator, EMG 1257 function generator, EMG 1172B signal generator, MEV TR-1660C bench multimeter
The following users thanked this post: Kleinstein
« Reply #10 on: September 29, 2022, 10:33:44 am »
The important thing is have one of theses band / oem's or clones lolll   be calibrated, if needed .....
