Hi fellows!! I have an ATF20b since 10/2012 and yesterday it was running well when the (both, A and B) output dead. The control panel is working well but there is no output, neither a little rf noise or some DC level, nothing!! I checked the mainboard's DC supply (5V, +/- 15 and others) and it seems ok. I checked the mainboard outputs (A and B) and they are completely dead too!
The only information about the conditions during the failure is that it happened when I was using the "A" output , in open circuit (no load) at 10.0 MHz.
Someone already heard about this kind of failure?
We don't have Atten service here in Brazil, do you know if is possible to find a ATF20B's circuit diagram or any kind of information?
Thanks and regards!
Some (bad) News!
Today, after several tests, I realized there was no clock in the AD9708AR, then the FPGA was not sending the clock signal. Next I turned off the generator, freezed the FPGA (using a freezing spray), turned it on, the FPGA put the 100.0 MHZ clock in the D/A Converter, the generator works fine for three or four minutes and fail again. I repeated this procedure three times and then I think there is no doubt the failure is in the FPGA Cyclone I! And now? What is you opinion? Do I need to replace the entire mainboard?
Thanks again!
