Author Topic: Hantek dso2d15 Noise from internal power supply  (Read 459 times)
Offline iw2evkTopic starter
« on: September 23, 2024, 06:49:39 pm »
somone have tried to modify internal circuit of dso2d15 for reduce the radiofrequency noise irradiated from scope?
I've placed a ferrite sleve on main cord but it's not sufficent for reduce noise.
All around the scope for about 1mt i've strong radio noise on wide spectrum frequencies.
need help , please
Roberto iw2evk
Online Aldo22
Re: Hantek dso2d15 Noise from internal power supply
« Reply #1 on: September 23, 2024, 07:32:43 pm »
I think it's the screen, not the power supply.
« Reply #2 on: September 24, 2024, 06:19:59 am »
Nothing to do ?
use a shieded cable for carring out the signal far away to oscilloscope ?
Online Aldo22
« Reply #3 on: September 24, 2024, 09:07:07 am »
Nothing to do ?
If you want to shield it for the other devices, a Faraday cage may help.  ;)
If you simply want to see less noise, you can try the following:
- Use a direct, short BNC connection to the DUT whenever possible.
- If you use the probes, use the 1x mode (for the smallest signals anyway).
  The less stuff hanging on the probe (sprung hook, alligator clip) the less “antenna” you have.
- Turn on the bandwidth limiter (BW 20M).
- If it does not trigger cleanly, a trigger holdoff can help (perhaps via PC).
- For repetitive signals, the "Average" acq. mode can help (or a little less the HR mode, for any signal type).
Noise is everywhere. Maybe it's not just coming from the scope?
I don't think the noise is that bad if you help a little.
In the attached image you can see a measurement with
- Probe (1x), sprung hook and alligator clip (i.e. completely normal).
- BW limitation on
- Average Acq. (8x).
This is a very small signal for a measurement with the probes (6.5mVpp) and it still looks reasonable to me.
« Last Edit: September 24, 2024, 09:19:38 am by Aldo22 »
Online Aldo22
« Reply #4 on: September 24, 2024, 09:47:18 am »
And before you curse the DSO2000:
It has pretty good sensitivity for such a cheap scope.
With a FNIRSI 1014D or 1013D you would see as much as in the attached picture of the signal above (50mV/div).
In this case the noise is not an issue.  :-DD
« Last Edit: September 24, 2024, 10:20:23 am by Aldo22 »
« Reply #5 on: September 25, 2024, 11:41:55 am »
i've order a double shelded 50 ohm bnc to bnc 1mt cable.
So i suppose can take awey the DUT from scope and reduce noise.
P.s. my test are on radio device, so i suppose i due buy a 50 ohm attenuator for reduce the signal from internal scope generator to input of radio..
Or i can make the attenuator with a kit ?
Online Aldo22
« Reply #6 on: September 25, 2024, 01:17:06 pm »
I'm not sure if that's a good idea. Maybe you pick up even more noise this way, because the cable is longer?
Can you show a picture/screenshot of what it looks like in your case?
When I place the probe directly on the scope/screen (picture 1), I see a lot of noise.
But in normal operation (picture 2) I don't think the noise is excessive.
The setting in the pictures is: probe 10x, without BW limitation, with HR mode and persistence 1s (100us, 20mV/div).
https://youtu.be/sWPRAKayC3g
« Last Edit: September 25, 2024, 01:20:16 pm by Aldo22 »
Offline Maximplus
  • Country: ru
« Reply #7 on: September 25, 2024, 08:20:50 pm »
Many people note that this oscilloscope has a primitive and noisy power supply. Its replacement or additional screening with filtration should help significantly. Unfortunately, the source is 2-channel, there are 5 and 12 V, inconvenient to replace. There is a lot of information on the redesign on youtube, including a video where a classic power supply with linear stabilization was used. Without pulse conversion. :-/O
The following users thanked this post: unicornio
« Reply #8 on: Today at 06:18:27 am »
Mhh..
can i add some ferrite bead on internal cable and/or ceramic capacitors on pcb  of voltage regolator output ?
I don't have  found imeges on web..
