i have to make fresh install to make TLA App 5.1 works correctly with TLA7E1. i guess there are some configuration setup going on during installation to configure the SW correctly with installed modules. short conclusion about TLA7E1 DSO module.. if you expect 100K waveforms per second, get a proper DSO, not this 7E1, this TLA7E1 may disappoint you (1 frame / 3 seconds update rate). i think it will be useful to work with TLA7AA4 LA module, synchronized or aligned triggering? etc, much like MSO functionality, but at abysmal one frame for 3 seconds update rate. this imho can be used for basic diagnostic repeatable error. for illusive intermittent bug, this is really not the tool to catch. but for me, its nice to have, it can show some signal that my DS1054Z cant, such as 100+ MHz "square" wave, and sub GHz signal (see attached).
there are some GUI bugs in TLA App 5.1 (2nd attachment shows TLA7E1 trigger configuration, but some options are clipped on the right i cannot reach them), i'm trying to install ver 4.4 to see if the bug is not there. but it cannot run it requires PCI-VXI Bridge Driver, does anybody have this driver? TiN? any pointer? i searched in the net and TiN's xdevs archive, no success. i tried to install dotnetfx 2.0, but the ver5.1 bug is still there. any help will be appreciated.
i'm learning TLA App along the way. i still cant play with logic module TLA7AA4 since i havent make probe head and circuit test setup for it and i still have much other things to do. currently trying to setup OS and get them right on 3 high end (was) instruments and waiting for parts, including this TLA714. fwiw..
