Author Topic: Peak Atlas ESR70 kept giving high ESR reading  (Read 599 times)
Offline danpopescuTopic starter
« on: June 16, 2023, 06:11:19 am »
My Peak Atlas ESR70 consistently kept giving high ESR reading.
I tried to compensate probes but it just ALWAYS fails.
Readings for 1 and 10 Ohm resistors are every time wrong.
Lately, ESR readings are all higher than 40 Ohm.
Did someone encounter this problem?
Online Kean
    • Kean Electronics
Re: Peak Atlas ESR70 kept giving high ESR reading
« Reply #1 on: June 16, 2023, 06:28:15 am »
Never seen this with mine.  I suspect damage due to measuring a charged capacitor above the threshold (it can do a controlled discharge within limits).
You might want to try contacting Jez from Peak.  He will know the device best, and he has a forum account here @PeakAtlas https://www.eevblog.com/forum/profile/?u=84715
Also on Twitter https://twitter.com/peakatlas/ and of course usual business contact details on their website
« Reply #2 on: June 17, 2023, 09:42:18 am »
Thank you.
I will try to contact Jez from Peak.
