Finally, guys, I found a solution for vertical 50p headers!
Firstly, such headers are not rare at all, it’s just that most manufacturers do not mark them as elevated or extra tall.
Secondly, there not many have in the lineup version 2x25.
Even Pololu produce such headers already many years but only in 2x20 version.
BUT if you try to search directly PC104
long pin, you can get a ton of them, its Chinese OEM headers which are very widely available on many markets... amazon, ebay and of course most cheap prices on
aliexpress. There exact option 2x25, but as a rescue option 2x5 also available (that may be staked in row by 5).
The main interesting part is that its high may be easily raised just by adding a plastic part salved from common pin header (pic from Pololu nicely illustrate that).
So now we have an all option for vertical 50p and
vertical HDMI sockets ![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
And as for the vertical HDMI sockets looks like Rigol use C2682172 in their DHO scopes, you can cheek it
here... but I think C5204145 definitely more robust.
PS
...is that we can put in the connector a bit lower, allowing the pod to be not as fat.
Extremely like the idea of low-ride 8p socket position!
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
