Screen dumps from the manual:
The specifications have been changed.
Now the storage depth is also 128k, like on the DSO2512G.
I think the oscilloscope part is more or less taken over from the DSO2512G.
The screen is a bit bigger (3.2 inch), but I think the resolution is the same for the oscilloscope.
Apparently the signal generator is a little less powerful.
There are contradictory data here.
The ZEEWEII Official Store says "1Hz-2MHz", the manual says: "5MHz(sin) 1MHz(other)".
And "Note: When the set frequency is greater than 1MHz, the square wave signal may show small horizontal jitter".
On DSO2512G I have not seen such jitter.
