Author Topic: Looking for a chinese bench power supply with open source firmware  (Read 1899 times)
Offline cedric!Topic starter
Hi All,
I would like to buy a bench power supply from china. I'm looking for a model that has been reverse engineered, and can therefore be re-flashed with open source firmware.
So far I've found "opendps", open firmware for these PSU's:
DPS5005 Uin:6-55V Uout:0-50V Iout: 0-5A Pout: 250W
DPS3003 Uin:6-40V Uout:0-32V Iout: 0-3A Pout: 96W
DPS3005 Uin:6-40V Uout:0-32V Iout: 0-5A Pout: 160W
DPS5015 Uin:6-60V Uout:0-50V Iout: 0-15A Pout: 750W
DP50V5A Uin:6-55V Uout:0-50V Iout: 0-5A Pout: 250W
DPS5020 Uin:6-60V Uout:0-50V Iout: 0-20A Pout: 1000W
https://hackaday.com/2017/03/07/open-source-firmware-for-a-cheap-programmable-power-supply/
https://johan.kanflo.com/hacking-the-dps5005/
https://github.com/kanflo/opendps
https://rdtech.aliexpress.com/store/group/DPS-digital-control-power-supply/923042_508466030.html
EEVblog #1265 - $53 360W Lab Bench PSU!
Are there other PSU's with open firmware?
Online dobsonr741
Re: Looking for a chinese bench power supply with open source firmware
« Reply #1 on: February 12, 2023, 04:47:50 pm »
Obviously your desire is the Riden open source firmware - does not exist yet.
The mega thread on Riden is here: https://www.eevblog.com/forum/testgear/ruideng-riden-rd6006-dc-power-supply/
Alternative firmware images posted frequently, however you can not build it from source. I won't comment on how those images might have came about.
Online nctnico
« Reply #2 on: February 12, 2023, 04:58:26 pm »
The following users thanked this post: I wanted a rude username
« Reply #3 on: February 12, 2023, 05:28:01 pm »
Why specifically Chinese? https://www.crowdsupply.com/envox/eez-h24005
I can't buy that one. (Not even when I'm willing to spend 399+18 dollars to buy a complete kit.)
Chinese is not a requirement. Cheap and open firmware is. (Cheap electronics usually have awful firmware)
« Reply #4 on: February 12, 2023, 05:34:18 pm »
If the source is not available, or not complete, can we call it open source?
I am very hesitant to buy something without the ability to change the firmware myself.
Online dobsonr741
« Reply #5 on: February 12, 2023, 07:02:00 pm »
Have you thought about what do you really want/need?
1. In case you need a workhorse power supply because you have a practical need, I suggest to be ready for a compromise between features/specs you really need vs. cost and open source. You might end up with multiple power supplies, as many of us did.
2. In case your interest is to develop code for a power supply then the direction is different: you can get going with OpenDPS on DPS5xxx, or perhaps you can roll your own firmware for Riden. Or any other cheap ready made hardware PSU with STM32 MCU you can easily replace, reverse engineer the hardware and roll your own firmware.
3. Maybe you want to develop the hardware and the firmware both - awesome, you'll find plenty of support here.
