Author Topic: Power supply current limiting - 150mA limit?  (Read 3194 times)
Offline NJ-TomTopic starter
« on: December 12, 2012, 12:00:55 am »
I recently purchased a Tenma 72-8345a power supply from MCM Electronics. It may be sold by Farnell / Element 14 in other countries.  I'll do a review of it later, but at this point I am trying to decide whether to keep it -
I found that the current is only adjustable down to 150mA.  Is that normal?  This is my first "real" power supply so I have nothing to compare it to.
Other than that the specs are reasonable - 1-36V, 0-3A (so it claims! It should say 0.15-3 A), switchmode.  Price: $150.  In my initial tests with a 6V motor (which is what I was trying to current-limit at 50 to 100 mA) both the displayed volts and amps were reasonably close to my multimeters; if I do a full review I will get specific readings.
That is, IF I keep it... your advice; please!
-- Tom
Offline cybergibbons
Re: Power supply current limiting - 150mA limit?
« Reply #1 on: December 12, 2012, 06:30:03 am »
Some supplies struggle with lower current limits, but the spec sheet says 0-3A, so it should go down to 0.
