Author Topic: Aneng takes the smartphone analogy too far? (ANENG 620A)  (Read 5212 times)
Online FungusTopic starter
« on: February 27, 2021, 05:15:10 am »
Even the on/off switch is like a phone's on/off switch and the function select buttons are where a smartphone volume buttons would be:
https://www.aliexpress.com/item/1005002124657734.html
« Last Edit: March 13, 2021, 03:17:18 pm by Fungus »
Offline james_s
Re: Aneng takes the smartphone analogy too far?
« Reply #1 on: February 27, 2021, 05:19:01 am »
Well I wouldn't want one, but I guess the market will decide.
Offline GrayCat
  • Country: ua
« Reply #2 on: March 13, 2021, 03:08:29 pm »
So, it' the " ANENG 620A " model. Just to make this topic searchable  ;)
The main question is: does it have the real mode switching? Their previous model 619A has an awful "Smart" mode, auto-switching between Volts, Ohms and continuity -- so you can NOT measure small voltages, neither small resistances. I expect Aneng to return to the manual mode switching.
Gray©at.
« Reply #3 on: March 13, 2021, 03:22:37 pm »
I changed the title.  :)
In the video you see both "Auto" mode and fixed modes (eg. when testing the LEDs).
The ranges are shown on the Aliexpress page:
I think this meter is for casual users. If you're really interested in fine measurements there are much better ones (eg. Aneng 870).
« Last Edit: March 13, 2021, 03:25:10 pm by Fungus »
Offline TimFox
Re: Aneng takes the smartphone analogy too far? (ANENG 620A)
« Reply #4 on: March 13, 2021, 04:54:16 pm »
In the still image shown above, two normal test probes are connected to a capacitor, but the readout is temperature in Celsius.
Offline wraper
  • Country: lv
« Reply #5 on: March 13, 2021, 04:56:40 pm »
So what? Measurement is displayed on top. Due to large capacitance, measurement was displayed after a few seconds.
« Last Edit: March 13, 2021, 08:55:36 pm by wraper »
« Reply #6 on: March 13, 2021, 05:23:11 pm »
The bottom half of the screen always shows temperature (the room temperature).
The capacitance result will appear in the top half of the screen when it's finished reading.
Offline TimFox
« Reply #7 on: March 13, 2021, 05:25:25 pm »
That dispels my mistake: I never view these videos.
Offline GrayCat
  • Country: ua
« Reply #8 on: September 01, 2021, 02:03:09 pm »
So, according to some YouTubes, this meter only has the "Smart" mode for V/R/continuity. You can not measure voltages below 0.5V, and resistances below ~~30 Ohm with it.
==> Trash Can.
The next my favourite will be the "Habotest HT116" == "GVDA GD128" multimeter. It has a slightly smaller (3.5 inch) but "Semi-Colour" VA display. And YES, it can be switched to manual V/R/Cont. modes, along with Auto/Manual ranges!  :-+
Gray©at.
