Author Topic: AN8008 US $19, 9999count, 1uV, 0.01uA, 0.01Ohm, 1pF resolution meter  (Read 317944 times)
0 Members and 20 Guests are viewing this topic.
Offline floobydust
Re: AN8008 US $19, 9999count, 1uV, 0.01uA, 0.01Ohm, 1pF resolution meter
« Reply #800 on: August 25, 2019, 10:05:43 pm »
That shunt measures about 0.015 ohms.
If I turn the rotary switch back and forth a few times, it can go down to less than 0.2 ohms but after a month it goes back up to several ohms or worse. Once it was over 50 ohms.
It seems to be the chinesium copper alloy the wipers are made of, with it's dull brown look and high sulphur content. The PCB has good gold ENIG finish still.
For the meter I bought it from the ANENG store, it seems the metals are such low quality I consider it too unreliable.  I could try electroplate the wipers with something.
Offline HKJ
    • Tests
« Reply #801 on: August 26, 2019, 06:59:05 am »
You are definitely doing something wrong, the shunt is not switched but permanently connected to the input terminals.
Offline The Soulman
  • The sky is the limit!
« Reply #802 on: August 26, 2019, 10:07:26 am »
Read the post on the previous page.  :-X
Edit: I cant get the link to work, but its a couple of posts back.
« Last Edit: August 26, 2019, 10:12:31 am by The Soulman »
Offline 001
  • Country: aq
« Reply #803 on: August 26, 2019, 12:01:54 pm »
Try to add simple solder bloob
Why not?
Offline ebastler
« Reply #804 on: August 26, 2019, 12:27:07 pm »
Hmm, which post? Could you indicate the reply number please?
Offline HKJ
    • Tests
« Reply #805 on: August 26, 2019, 12:30:52 pm »
It looks like he is not talking about the internal current shunt, but about measuring sub-ohm resistors with the meter.
Offline BravoV
  • +++ ATH1
« Reply #806 on: August 26, 2019, 12:45:31 pm »
... about measuring sub-ohm resistors with the meter.
Sub-ohm measuring with 2 wires only meter ? Reliably ?  ::)
Offline HKJ
    • Tests
« Reply #807 on: August 26, 2019, 12:51:47 pm »
Most of the better meters uses separate paths for current source and measurement to the connector, i.e. the switch resistance will not affect the result. That is not always the case on cheap meters.
Offline BravoV
  • +++ ATH1
« Reply #808 on: August 26, 2019, 12:59:47 pm »
Yeah, most bench top meters has 4-W capability, but never seen at "handheld" DMMs, except for LCR meter, but its different animal by it self.
Offline HKJ
    • Tests
« Reply #809 on: August 26, 2019, 01:08:40 pm »
I did not talk about bench meters, but standard hand held meters with two terminals where the current source and voltage measurement do not share a switch terminal.
And yes benchmeters is something else and considerable better at low ohmic measurement.
Handheld multimeter with 4 terminal ohm do exist: METRAHIT IM XTRA but it is probably just as expensive as a bench meter.
Offline rafik23
  • Country: dz
« Reply #810 on: December 19, 2019, 02:21:12 pm »
moved to new topic
« Last Edit: December 20, 2019, 02:41:43 am by rafik23 »
Offline Gandalf_Sr
« Reply #811 on: December 19, 2019, 09:14:28 pm »
@rafik23
I'm confused, does your post have anything to do with the AN8008?
If at first you don't succeed, get a bigger hammer
The following users thanked this post: egonotto, tooki, umbro
Offline rafik23
  • Country: dz
« Reply #812 on: December 20, 2019, 02:16:50 am »
hi
my post is for dtm1106EN i want to analyse data
Offline ebastler
« Reply #813 on: December 20, 2019, 06:26:43 am »
hi
Then please open a new thread, with a descriptive title. (It should mention the model of meter you are actually talking about.) Thanks!
The following users thanked this post: TheBay, tooki, djos, Jacon, rafik23
Offline djos
« Reply #814 on: December 20, 2019, 06:59:45 am »
Noobs! :palm:
Offline 001
  • Country: aq
« Reply #815 on: December 20, 2019, 05:48:29 pm »
Noobs! :palm:
I`m noob for at last 56 years, is it a problem? Why do You discriminate noobs?
Offline djos
« Reply #816 on: December 20, 2019, 08:18:29 pm »
Noobs! :palm:
I was referring to his post count, all 3 posts were in this topic.
Offline tigrou
« Reply #817 on: January 02, 2020, 02:18:35 pm »
Hello. I have one question related to this multimeter (and other multimeters in general) :
When measuring voltage (eg : 220V AC) with probes endings plugged into socket 2 and 3 (the last two sockets, starting from left), is there safe rotary switch positions other than "V" and "mV" ?. AFAIK "A"and "mA" positions are a big no-no (since it's basically a short-circuit) but what about others ? (eg : ohms measurement or continuity test) ?
Offline Fungus
« Reply #818 on: January 02, 2020, 08:07:00 pm »
No.
(and I have doubts about the mV position)
nb. Even if the switch is on 'V' the leads can still be in an unsafe position... be sure to triple-check everything.
Offline bobale
  • Country: cs
« Reply #819 on: January 15, 2020, 06:53:10 am »
Hello guys  :)
So, anyway, I've stupidly managed to burn input divider 5MΩ resistor (R30) on my AN870 by trying to measure output of a (unloaded) CCFL backlight driver  |O.
Since 5MΩ is not really a standard value, and as far as I've managed to find out, this resistor is MELF 0.25%, the best I could manage to find locally was two in parallel 10MΩ 1% metal film resistors. Voltage measurement works now, but it is showing a little bit low. Before it would be almost bang on 10.000V when I feed it AD584 10V voltage reference. Now it reads something like 9.954.
Question is: will I ever be able to get back the accuracy with 1% resistors (can't really find any better locally), should i try calibration procedure, or should I scrap the multimeter?
The following users thanked this post: exe
Offline Fungus
« Reply #820 on: January 15, 2020, 08:04:59 am »
You could buy a load of cheap 1% 4.7M resistors and pick out the two that are best matched.
OTOH the calibration will probably be done with of error so you might have to find two that are slightly mismatched, by just the right amount to make it work (put a pot in series with one of them and dial it in to find the exact ratio needed). :popcorn:
Also think about getting a Fluke 101 for measuring things like that in the future.
« Last Edit: January 15, 2020, 08:57:23 am by Fungus »
Offline bobale
  • Country: cs
« Reply #821 on: January 15, 2020, 09:51:09 am »
I rarely need to measure that high voltage, CCLF backlit monitors are on the way out anyway.
Thanks for the suggestion. I have 4.7M, 5.1M and 10M, 10pcs each, and will combine them in some way to get the it to measure correctly. As far as I'm aware, those two 5M resistors (R29 and R30) are only for measuring voltage, right? Other things shouldn't be affected?
Offline Fungus
« Reply #822 on: January 15, 2020, 11:55:35 am »
Hang on...
Looking at your photo closely I see they're the input protection resistors (leading to the PTC). It's not a voltage divider at all, it's just a 10M (approx) resistance to give a high impedance input and I don't think they're high precision at all. Maybe your problem is simply that you put in a much higher value.
« Last Edit: January 15, 2020, 11:57:46 am by Fungus »
Offline bobale
  • Country: cs
« Reply #823 on: January 15, 2020, 12:00:46 pm »
Here's higher res photo in the attachment. This should be diveder as it is going straight to the chip, not to the PTC.
Offline HKJ
    • Tests
« Reply #824 on: January 15, 2020, 12:43:26 pm »
Hang on...
The 10Mohm resistors are always part of the input voltage divider and is used in volt AC/DC, it can also be used in other ranges, but usually a about 1Mohm input resistor is used for them and that resistor is not used in a voltage divider only as protection.
