Author Topic: AN8008 US $19, 9999count, 1uV, 0.01uA, 0.01Ohm, 1pF resolution meter  (Read 321949 times)
0 Members and 21 Guests are viewing this topic.
Offline MacMeter
Re: AN8008 US $19, 9999count, 1uV, 0.01uA, 0.01Ohm, 1pF resolution meter
« Reply #700 on: November 09, 2017, 04:26:37 pm »
Offline BroMarduk
« Reply #701 on: November 09, 2017, 04:42:39 pm »
Link fails
Try copying then pasting the entire link into the browser.   When you see the link color change part way through, it's almost a sure sign that you will need to paste the link in manually....
Offline MacMeter
« Reply #702 on: November 09, 2017, 05:13:27 pm »
Link fails
First thing I did. Found it manually.
Online IanB
« Reply #703 on: November 09, 2017, 05:23:49 pm »
Here's the link to the other thread to save people searching:
Latest 9999 counts dmm released! AN8009 for $24 now!
Offline exe
  • self-educated hobbyist
« Reply #704 on: November 10, 2017, 06:14:59 pm »
Guys, I have a problem never seen reported before. I cannot disable auto powerdown. Even if I do as manual says (hold select button when switching it on) it beeps 5 times and auto power downs after 15 minutes. This is really annoying... Any ideas how could I fix this? Or may be I'm doing it wrong as both AN8008 and ZT102 behave the same way for me.
Offline metrologist
« Reply #705 on: November 10, 2017, 06:51:01 pm »
I did not know you could disable it. Thanks!
Offline stroma
  • Country: bg
« Reply #706 on: November 15, 2017, 11:33:23 am »
I added RANGE and REL buttons to my AN8002. Let see if button modification is possible with the AN8008.
What kind of switches have used? Isn't the rubber buttons to soft for normal push buttons?
I used these switches
https://www.arrow.com/en/products/evp-ayf1ba/panasonic
I used 1mm thick PCB for the button separator. I'll take more pictures when I modify my second unit and the AN8008.
This is probably the best buttons modification I've seen.
Could you share more detailed description for this modification?
How the PCB separator is attached?
How the button rubber is cut - all the way in two separate pieces or partially?
Offline 001
  • Country: aq
« Reply #707 on: November 18, 2017, 06:58:55 pm »
I check "kazus" forum
And I`m anxious now
Few users sad what stock linearity of readings is not linear
i.e. AN800# use some firmware trick  to avoid last count jitter and to indicate "beautiful" zero  at shorted leads and low  (i.e. noisy?) levels   :-//
What about more tricks?
« Last Edit: November 18, 2017, 07:02:44 pm by 001 »
Online floobydust
« Reply #708 on: November 19, 2017, 07:49:56 pm »
I found the AN8008 does not have the IC pin bonded out for the extra switches. So this mod I believe did not work out.
Offline Rossix
« Reply #709 on: December 04, 2017, 01:12:05 pm »
Hi, I recently bought the AN8008 tester at Banggood, I've made some changes to the tester, as recommended at
https://www.jackenhack.com/aneng-an8008-modify-for-better-accuracy-faster-readings/ .
I did some measurement tests on low currents: in DC current there are no problems, the measurements are correct, both on mA DC and on uA DC, then I tried to measure in AC current at 50Hz network and 230VAC, using a resistor in series with the tester, in the uA AC range there are no problems, but in the mA AC range the measurements start from 7 - 8 mA AC with errors even 50%, then as I increase the current, it becomes more and more precise.
When I try to measure currents of 1, 2 or 3mA AC, the tester remains on 0 mA AC.
I ask if you have also found the same defect of the tester and if you have a solution about it. I have other multimeters and the problem with these obviously does not show up but they work properly, thanks for the help.
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #710 on: December 04, 2017, 02:27:40 pm »
Mine beeps 5 times (and this is annoyng) but does not power off... but mine has a different silkscreen and mybe different firmware (see my previous post).
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline stj
« Reply #711 on: December 04, 2017, 03:33:31 pm »
just differnt settings in the eeprom.
Offline Mr. Scram
  • Display aficionado
« Reply #712 on: December 11, 2017, 01:21:01 am »
Does anyone know whether this thing uses fast or slow blow fuses?
Offline stj
« Reply #713 on: December 11, 2017, 01:35:23 pm »
i know they are not fast enough!  :palm:
you need to adapt it to 20mm FF rated fuses.
Offline Crumble
« Reply #714 on: December 16, 2017, 01:52:15 pm »
I opened a fuse previously, and there are just copper wires in it and no sand whatsoever. I guess these are unlikely to have been checked for breaking speed. You might be able to use these, they claim to be quick blow, but I wouldn't hold my breath:
https://www.ebay.com/itm/290754775264
https://www.ebay.com/itm/300757393643
Online Fungus
« Reply #715 on: December 16, 2017, 03:36:08 pm »
Even if they're quick blow they're not going to save you from anything.
a) Stick to low voltage work with this meter
b) Think twice before selecting a range with a fuse in it (unfortunately these meters don't require you to move the cable to a different connector to get a fused range).
Offline Crumble
« Reply #716 on: December 17, 2017, 12:20:09 pm »
Very true, it is unlikely to help when using mains, but it might just save you a cascading failure in the DUT when probing around, so I would recommend trying to buy a new set of fuses rather than bridging them. That is why I gave the links. I goofed when measuring a NiCd battery for a cordless drill, these are known to be capable of some serious currents.
Online Fungus
« Reply #717 on: December 17, 2017, 05:10:26 pm »
One of the real weak points of these meters (IMHO) is that the fuses are a non-standard size and it's almost impossible to find replacements.
« Last Edit: December 17, 2017, 05:15:59 pm by Fungus »
Offline stj
« Reply #718 on: December 17, 2017, 05:48:26 pm »
that's not true, 10mm is a standard size, just not one that should be in a meter!
The following users thanked this post: MWisBest
Offline Mr. Scram
« Reply #719 on: December 17, 2017, 05:49:46 pm »
I had no trouble finding replacements on eBay. You might need to buy leaded ones, but that shouldn't really be a problem.
Offline soubitos
  • Country: gr
    • I sell on Tindie
« Reply #720 on: December 23, 2017, 05:32:07 pm »
I just replaced the fuse holders and fuses in my ANENG AN-8008.
I got 1808 SMD fuse holders which cost around 0.20$ each, 250mA fuses cost around 0.40$ each and 10A fuses around 0.25$ each...
Total cost to replace the original fuses was around 1$ total....
Fuse holders sit nicely in the old holders spot and i soldered them from the sides with soldering iron, no need to even bother with a hot air gun etc. Just made sure to remove old (lead free?) solder which also smelled funny
The following users thanked this post: ebastler, floobydust
Offline Mafketel
« Reply #721 on: February 02, 2018, 03:39:23 pm »
I doubt those are rated for high voltages ..... not enough physical distance
Offline stj
« Reply #722 on: February 02, 2018, 06:29:47 pm »
the fuses are only used for current reading, and current range is limited to 36v - so no problem.
Online Fungus
« Reply #723 on: February 02, 2018, 07:22:01 pm »
Limited by what?
Is there something preventing me from applying more than 36V to the current input?  :popcorn:
« Last Edit: February 02, 2018, 07:24:36 pm by Fungus »
Offline HKJ
    • Tests
« Reply #724 on: February 02, 2018, 07:34:13 pm »
Limited by what?
The specifications says 36V, you are not allowed to make mistakes like leaving the probes in the current holes when measuring mains!
