Is that a new model of those cheapo meters?
Looks intriguing, does it have a square wave
output?
Update: Yes it does - read the description (duh!)
"*Square Wave Output:50Hz/100Hz/200Hz/300Hz/400Hz/500Hz/600Hz/700Hz/800Hz/
900Hz/1000Hz/2000Hz/3000Hz/4000Hz/5000Hz"
![](https://www.eevblog.com/forum/testgear/an8008-us-$19-10000count-1uv-0-01ua-0-01ohm-resolution-meter/?action=dlattach;attach=327865;image)
The AN8001 has been analyzed to death here, I assume it's quite similar inside.
https://www.eevblog.com/forum/testgear/aneng-an8001-6000-count-true-rms-multimeter/
It has a uA range, which the AN8001 is lacking. And 9999 counts.
I bet all the people who rushed out to buy the AN8001 a few months ago will be upset by that.
Pretty impressive, if safety is not a concern.
Apparently, does temperature too:
Yep.
I was thinking about getting an AN8001 for Arduino club but lack of uA bothered me. This is much better, I might have to take the plunge.
All the review videos show decent autorange speed, fast continuity test, etc. It even does true RMS up to 1kHz and comes with lots of accessories and a bag.
It even displays '°C' ... ?
Regarding safety: The AN8001 was badly designed. It has an "OFF" position right next the the "mA" position. I bet the person who put in two "OFF" positions thought he was being clever, but... ![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
You mean like the 121GW? ![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
The 121GW doesn't share the mA socket with the V socket, but yes, it's still bad design. Even if the leads are in the right place you have to switch past a bunch of other ranges (eg. Ohms) to get to the voltage ranges. Not ideal if the leads are connected to something at the time.
Comments, Dave?
![](https://www.eevblog.com/forum/testgear/an8008-us-$19-10000count-1uv-0-01ua-0-01ohm-resolution-meter/?action=dlattach;attach=327884;image)
Not an issues when the mA range is on it's own socket.
Only the uA range shares the V jack.
Comments, Dave?
I like having the 2nd OFF position. Having only one in the traditional position makes your meter Voltage range racist
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
If you do a lot of current measurement then the right hand off position can be handy.
Of course you can simply ignore the extra OFF position if it bugs you or doesn't suit your usage.
I kinda like the look of this cheap meter for basic budget low level electronics work, but if it's like the 8001 inside then it's your typical cheapie, albeit a bit more useful than most with those extra ranges.
Out of curiosity I've ordered one.
It's still a small issue, IMHO.
I like having the 2nd OFF position. Having only one in the traditional position makes your meter Voltage range racist ![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
If you want to add value, get rid of
both of them and put in a proper mechanical on/off switch.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
These new ones seem to have really good performance for auto-ranging, continuity, etc. The previous generation were horrible for that.
I really like the look of this one. I'm not sure what I'd use the square wave output for though.
(Can it flash a LED? Will it make a speaker buzz?)
Me, too.
I can use the meter to switch my device on and off, it's a
feature!
Ordered from a cheaper seller, here:
Neener, neener. I hope yours takes longer to arrive.
Snif.
you can find it as low as $15 ...
RedSky got his for even less than that.
Is there some specialized site for Chinese multimeters we're not aware of, or perhaps deals simply differ from country to country?
With just one current probe position is there but one highest range current fuse?
Nice, addition of uA makes it a lot better. I bet it will still have those silly little 10mm fuses though :-/ I ended up buying leaded ones from RS and cutting the leads off.
