Not an issues when the mA range is on it's own socket.
It's still a small issue, IMHO.
I like having the 2nd OFF position. Having only one in the traditional position makes your meter Voltage range racist ![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
If you do a lot of current measurement then the right hand off position can be handy.
Of course you can simply ignore the extra OFF position if it bugs you or doesn't suit your usage.
If you want to add value, get rid of
both of them and put in a proper mechanical on/off switch.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
I kinda like the look of this cheap meter for basic budget low level electronics work, but if it's like the 8001 inside then it's your typical cheapie, albeit a bit more useful than most with those extra ranges.
These new ones seem to have really good performance for auto-ranging, continuity, etc. The previous generation were horrible for that.
I really like the look of this one. I'm not sure what I'd use the square wave output for though.
(Can it flash a LED? Will it make a speaker buzz?)
Out of curiosity I've ordered one.
Me, too.
