How does one check which firmware version is in the meter. I assume the firmware version is displayed briefly at power on, which in my case displays "
U - 1.18".
Does this indicate version 1.18? Asking because there is no v1.18 at
https://www.eevblog.com/product/121gw/. The versions go from 1.17 to 1.21
It would be nice if the user manual mentioned how to check which firmware version is installed after an update. Also, it would be helpful if the beginning of the manual would mention that the firmware version is displayed briefly when powered on (if, indeed, this is correct).
UPDATE: Just upgraded to 2.05 and confirmed that powerup message is version number. Would still be nice to have this info in user manual.
