Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Amp Clamp Overload - Is it Possible?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Amp Clamp Overload - Is it Possible? (Read 733 times)
Shredhead
Regular Contributor
Country:
Yup
on:
December 22, 2021, 08:13:06 pm »
Got this
https://www.kleintools.com/catalog/clamp-meters/acdc-digital-clamp-meter-auto-ranging-400-amp
meter to measure DC current on automobile as it's a pain to worry about the fuse popping on a regular multimeter inline.
Is it possible to damage/destroy an amp clamp meter by measuring too high of a current in a setting? I'm not quite sure how Hall effect sensors are designed.
I'm going to do a 10 turn wrap cord around the clamp to increase it's accuracy in it's lower ranges to measure parasitic drain but don't want to run into any problems as I plug fuses back in because the current can spike.
Logged
Fungus
Super Contributor
Country:
Re: Amp Clamp Overload - Is it Possible?
Reply #1 on:
December 22, 2021, 09:09:40 pm »
I don't think you can damage the sensor with a magnetic field but you can certainly magnetize the clamp and it will need degaussing afterwards.
Last Edit: December 22, 2021, 09:35:31 pm by Fungus
Logged
Shredhead
GerryR
Frequent Contributor
Country:
Reply #2 on:
December 22, 2021, 11:07:43 pm »
With most of the clamp-meters I have used, when measuring DC current you have to zero the meter because of residual magnetism in the clamp after a reading. The zero function is part of the meter.
Logged
Still learning; good judgment comes from experience, which comes from bad judgment!!
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
