Author Topic: HP 8644 (866x) internal modulation generator jitter, need firmware update?  (Read 1899 times)
Offline JurisTopic starter
Working with my repaired 8644A (options 002,004,007,010) I noticed quite jitter on generator modulation audio output.
If I choose square output there is 600 ns waveform jitter present.
When using sine output there isnt any.
Same internal modulation generator (NSM OSC) PCB is used in whole 8644/64/65 generators series, can you look at it ?
Is it known bug / limitation of internal LF generator ?
My suspect is old firmware - 2.10.0 on bay I seen 8644 advertised with 4.2 (?) firmware versions.
Can you look what FW version is in your 8644A/B (showing for couple of seconds at startup)?
Anybody have firmware files newer than 2.10? more information about firmware versions ? is firmware inter changeable between 8644 and 8664/5 ?
Juris
yl3cb
p.s.
If anybody want to upgrade 8644 to 2GHz option, on bay is available doubler module for 70$, also other modules from 8644...
Offline dthung
Do you know the std doubler on bay is compatible with 8644B or not? Thz.
There isnt any difference between 8644A and 8644B, what I can find, except default configuration - 8644B include option 004 (COAX DSC - low noise) and 007 (NSM OSC - modulation generator) by default.
Both use same STD DOUBLER (08644-61040) module for 2GHz range extension.
Juris
p.s.
what is your 8644 FW version ?
Offline dthung
Thz for the information. My 8644B can't power up at this moment. I bought it cheap on bay when it was listed as not-working (didn't power up). Now I just need a good weekend to fix it so that it can power up, hopefully.  :P
Dick.
