Author Topic: R&S HMO HOO12 Scope Sale at TEquipment.Net  (Read 5316 times)
Offline RF-EngineerTopic starter
« on: July 29, 2015, 05:35:44 pm »
This is worth considering.  100 MHz upgrade included for a real R&S scope.  No idea how it compares with Agilent (Keysh...whatever, etc).  Possibly the EEV discount code applies too.
http://www.tequipment.net/Rohde-&-Schwarz/HMO-Max/Digital-Oscilloscopes/?b=y&v=7910
Paul
Offline dadler
Re: R&S HMO HOO12 Scope Sale at TEquipment.Net
« Reply #1 on: July 29, 2015, 07:52:54 pm »
Seems to have some interesting features and options, especially for the price.
anyone know if this a true R&S product or a rebrand?
I couldn't immediately find the cost of the MSO logic probes.
Offline commie
« Reply #2 on: July 29, 2015, 07:59:36 pm »
It's a HAMEG. At a very good price I might add.
Offline dadler
« Reply #3 on: July 29, 2015, 08:03:10 pm »
Sure, but Hameg == R&S.
Offline commie
« Reply #4 on: July 29, 2015, 08:11:03 pm »
Yep, you are right, R&S acquisition HAMEG some time back, however we all know R&S is top flight stuff. Before the take over though HAMEG made high quality test gear all the same. Old Hameg scopes go for good money on Ebay still.
« Last Edit: July 29, 2015, 08:14:32 pm by commie »
Offline dadler
« Reply #5 on: July 29, 2015, 08:14:51 pm »
I know, maybe I asking my question wrong. For example, LeCroy/Agilent/etc rebadge other manufacturers products under their own names. I am wondering if this R&S/Hameg scope is truly manufactured by the badged companies, or is an oursourced product.
It looks like a real Hameg scope, but the price is throwing me off...
Offline VE7FM
« Reply #6 on: July 29, 2015, 08:15:31 pm »
If every option was enabled I'd order one to replace a 1054Z.
Deep in the heart of the state of the art
Offline dadler
« Reply #7 on: July 29, 2015, 08:23:28 pm »
It is only 2 channel vs the 1054z.
Offline VE7FM
« Reply #8 on: July 29, 2015, 08:27:42 pm »
2 channels plus trigger would be enough for my use. The bonus would be a logic analyzer and a function generator(even if limited). But I would need all of the trigger and decode options.
Offline commie
« Reply #9 on: July 29, 2015, 08:29:10 pm »
Hameg scopes are not low cost by a long shot, in fact I was looking at Hameg scopes the other day and if that same scope was selling in the U.K., we would be paying in pounds(£) what you are paying in dollars($).In fact I'm quite envious of you guys in the States :popcorn:
Offline onrainbow
« Reply #10 on: July 29, 2015, 08:49:13 pm »
Interesting. How does it compare to rigol 2072a? You can hack the Rigol  to 300mhz with a lot more memory(14 vs 1M) .
Offline dadler
« Reply #11 on: July 29, 2015, 09:19:13 pm »
The DS2000 series has 54MPts of memory vs 1M for this scope, and twice the sample rate.
Offline SaabFAN
« Reply #12 on: July 29, 2015, 09:52:03 pm »
Hm... Somehow I fail to see why I should pay 1000$ for this scope while I can get the same/better (Scope + Signal-Generator with MUCH BETTER Specs and Counter, 6000count DMM) equipment for roughly the same amount by getting Rigol, Hantek, Owon or Siglent Equipment.
Did I miss something?
Offline nctnico
« Reply #13 on: July 29, 2015, 11:00:56 pm »
You can always choose for the Rigol MSO1000Z. Dunno how well it works but it is cheaper than the Hameg and has a higher display resolution.
Offline Muxr
« Reply #14 on: July 30, 2015, 01:26:27 am »
The MSO part is interesting, and the price seems ok. If I was in a market for a lower end MSO I am not sure I would consider it over a Rigol MSO1104Z though. It is better spec-wise in many ways. More analog channels, more digital channels, 3x higher waveform update rate, more memory..
I dunno, I hear the UI is pretty good on Hamegs, so that might be a factor in Hameg'a favor.
Offline Wuerstchenhund
  • Able to drop by occasionally only
« Reply #15 on: July 30, 2015, 06:09:07 am »
Not just the UI. The HMO also has a digital pattern generator, which is pretty rare. Plus it has much better FFT (128kpts) than any Rigol scope, and a much lower noise floor than the Rigols.
And the firmware that R&S/Hameg puts out is generally worlds apart from the bug feast that can be found in Rigol kit.
Offline nowlan
« Reply #16 on: July 30, 2015, 02:14:16 pm »
I asked for a quote last year. This is in aud, so gst=10% on top i suspect.
Hello Anthony:
I have just received your request for information on the HMO1002 Oscilloscope.
The pricing is as follows:
The base price of the HMO1002 is:
HMO1002 (50MHz) is $1,100
The option to take the unit to 70MHz is +$170 on the base price.
The option to go from 70MHz to 100MHz is +$170 on the base price.
The option to go from 50MHz to 100MHz is +$340 on the base price.
1100+340 = 1440 aud == 1047.53 US Dollar
Makes me doubt the $2200 list on tequipment.
I ended up getting a hmo722 for a good price on the forum.
(the 100 MHz version is 998 Euros) = 1090usd. So free Lin/Can decoder.
« Last Edit: July 30, 2015, 02:27:23 pm by nowlan »
