Author Topic: Cheap spectrum analyser  (Read 3863 times)
Offline LukeWTopic starter
« on: June 10, 2014, 06:46:23 am »
Anyone have any recommendations for a spectrum analyser that is not a rubbish toy but is also low-cost and good value?
In terms of specific budget, let's say a couple of k, or $5k at the most.
I've been looking at the Rigol DSA1030 at the moment... anyone with experience with that unit, or recommendations for anything else that is similarly priced?
It would be really desirable to have something that runs up to 3 GHz, for RF work with 2.4 GHz devices.
Offline VK5RC
Re: Cheap spectrum analyser
« Reply #1 on: June 10, 2014, 10:47:02 am »
What frequency do you have to get to,  good second hand ok?  A trusted HP SA?
Offline KJDS
    • my website holding page
« Reply #2 on: June 10, 2014, 10:55:06 am »
Which country are you in? Good second hand equipment is a lot more readily available in some countries than others.
Offline Psi
« Reply #3 on: June 10, 2014, 11:54:19 am »
Does it need to be a all-in-one unit with a LCD?
Some of the PC based analyzers are quite good.
Also do you need a tracking gen
Offline nctnico
« Reply #4 on: June 11, 2014, 11:14:37 am »
Does it need to be new? Advantest has several models with an LCD screen which certainly can be bought from Ebay with that budget.
Offline dannyf
« Reply #5 on: June 11, 2014, 11:16:31 am »
Depending on your requirement, those SDR sticks can be used as a spectrum analyzer.
Usually around $10 - 20 each.
Offline w2aew
    • My YouTube Channel
« Reply #6 on: June 11, 2014, 03:47:51 pm »
With the current promotion that Tek is running on the MDO3000 series of mixed domain oscilloscopes, you get the 3GHz spectrum analyzer upgrade for free.  In your case, you can think of this as a basic 3GHz spectrum analyzer with a free scope attached.
FAE for Tektronix
