Author Topic: Multimeter With Accurate Temperature Measurement  (Read 14295 times)
Offline kripton2035
Re: Multimeter With Accurate Temperature Measurement
« Reply #25 on: June 11, 2014, 09:19:58 am »
use a "max" feature of the infrared gun if it has one ?
Offline kripton2035
« Reply #26 on: June 11, 2014, 09:23:24 am »
you can also make yourself a small device with an NTC or a PT100 as a probe
once calibrated in the temperatures you need a simple NTC can be really precise (and cheap)
a µcontroller with a small display and that's all.
I made one but with a ds1820 probe so goes only to 125°C but would be easy to adapt to your case.
