Author Topic: Power Supply Calibration?  (Read 1519 times)
Offline somlioyTopic starter
  • Country: no
« on: May 13, 2013, 02:37:29 pm »
Hi
I had to repair my E3644 and now it needs a calibration. I dont fancy sending this heavy beast away, so I'd prefer do to it my self.
So the question is how could I calibrate this to get it close to its specs? I'm considering buying a bench meter (3478 or 3457). With either of those the voltage part should be ok?
What about the current part? Could a homebuilt dummy load do or is it prefered to use a proper programable electronic dc load? Service manual suggest a 0.01ohm , 0.01% shunt tho, which I dont have.
Offline babysitter
  • pushing silicon at work
Re: Power Supply Calibration?
« Reply #1 on: May 13, 2013, 03:24:57 pm »
Either calibrate it against your own multimeter, or look out for another electronics guy in your neighbourhood. Maybe go doorbell ringing to the next tv repair shop.
Greetings
Hendrik
I'm not a feature, I'm a bug! ARC DG3HDA
