From lurking on the forum, I know that many here are fans of the HP/Agilent/Keysight 54645D unit.
I have recently gotten one that experienced some less than gentle handling during shipment.
The display comes up, and the corners are square, but the display is rotated a few degrees from vertical.
The CRT seems to be sitting square with respect to the front cover, so I suspect that there must be some sort of rotation adjustment that can address this.
I have not opened the unit up yet. I downloaded the manual, and I reviewed Chapter 8 regarding adjustments. The chapter refers to horizontal and vertical holds, brightness, etc., but I don't see anything about rotation adjustment.
So, I am seeking knowledge and advice from the many experts here as to how to adjust this before I go tearing into the unit.
Any help or insight is greatly appreciated!!
