Posted on groups.io as well but thought I may have better luck on EEVBLOG.
The Agilent 85092-60007 3.5mm, 2-port, 30k-9GHz ECal has a USB port marked "USE WITH PNA SERIES". My Agilent E8367A PNA has the 9GHz option enabled. When I connect the ECal to the PNA (via USB), the OS detects the device. Looking under Device Manager, it lists "Agilent USB ECal Module". Driver Details shows e-TEK Labs version 1.2.0.0, Agecalv1.sys The ECal's Green LED eventually turns on solid.
Selecting the calibration wizard and ecal, it displays "An ECal module was not found. Please be sure the ECal module is connected properly. (You may need to disconnect and re-connect the USB cable)"
I tried two different known good cables, plugging into the front USB port. I have a powered hub plugged into the rear that has the mouse and keyboard attached. I tried connecting the ECal to that as well. In all cases, the OS finds the devices but the PNA fails to locate it.
From the small clues Agilent provided, it seemed there was an A,B & C revision. A was sold by HP and did not appear to support USB. Looking at photos for the B & C, they do not appear to be marked. This particular one has no revision markings as well. The latest manual I have for the PNA calls for the 85092C. Looking at an older document, it appears they supported the revision B as well:
http://www.av.it.pt/Medidas/Data/Manuais%20&%20Tutoriais/11-%20PNA%20NetWork%20Analyser/CD1/technical_specifications.pdfLooking on the PNA's disk, there was a directory that was marked Ecal Drivers. Inside there were two directories for Floppy#1&2. I had installed the PNA software using VirtualBox. I installed these two disks (HP ECal 01.008). Looking at the help file, it looks like they were used to setup a PC that would sit between the VNA and ECal to control it (see attached). This was maybe some work around for customers trying to run old ECal units.
Any ideas on how to determine the revision of the 85092 ECal? Are both the C&B revisions are compatible with this PNA? Any thoughts on what it would take to get it working?
