Hi Group,
I recently purchased a used Agilent N5772A 600V 2.6A Power Supply. This is a 1.56 kW Power supply in a 1U (43.6mm or 1.72 inches) high package weighing 8.5 Kg or 18.7 lbs.
Here is a link to the Power Supply on the Keysight website.
http://www.keysight.com/en/pd-839197-pn-N5772A/power-supply-600v-26a-1560w?nid=-35683.384510&cc=CA&lc=engFront PanelOn one side there is the nameplate and on the other side the controls and display:
OverviewThis picture shows an overview. In the top left there is the an interface board. This power supply has HPIB (IEEE 488), LAN and USB interfaces. Underneath the interface board there looks to be a control board.
In the center on the left side there is the an output filter board.
There are two power boards each producing 600V 1.3A that are connected in parallel.
At the bottom of the picture is an auxiliary power supply and input filter.
Three fans keep the whole thing cool.
Input Filter and Auxiliary Power SupplyPower BoardThere are two of these boards in the unit. Each board contains a Power Factor Correction stage and output section. There are two transformers and one inductor in the Output section.
Interestingly the boards are marked Nemic Lambda:
And TDK Lambda sells these remarkably similar power supplies:
Link to the TDK Lambda website:
http://www.tdk-lambda.com/products/sps/ps_system/gen/indexe.html#Interface BoardThe Interface board is clearly marked Agilent. The N5772A has LAN and USB interfaces which are not included on the TDK Lambda models.
Output FilterHere is a picture of the output filter:
Regards,
Jay_Diddy_B
