Author Topic: cJTAG FLASH programmer CCS and F280049  (Read 645 times)
Offline JesterTopic starter
« on: April 28, 2021, 06:57:31 pm »
I have been playing with a TI F280049 for a few days. So far only on a Launchpad development board that has a built in FLASH programmer and debugger. I now want to move to a custom board using just the F280049 so I will need an inexpensive FLASH programmer.
I can debug on the development board if necessary so I only need FLASH programming capability, preferably with the cJTAG interface because of the low pin count. TI recommended their XDS200, priced at about $500 so that breaks the inexpensive criteria.
Any suggestions?
Hmm..... I suppose I could use the launchpad development board as a FLASH programmer by simply redirecting the signals to the custom board.
« Last Edit: April 28, 2021, 07:00:50 pm by Jester »
Offline BFX
  • Country: sk
Re: cJTAG FLASH programmer CCS and F280049
« Reply #1 on: April 29, 2021, 08:31:06 am »
Yes you can use Launchpad development board as a programmer/debugger.
Remove those jumpers and wire some cables to your new board.
