Author Topic: Agilent MSO 5000/6000/7000 - anyone hacked these scopes?  (Read 284059 times)
0 Members and 17 Guests are viewing this topic.
Offline Howardlong
Re: Agilent MSO 5000/6000/7000 - anyone hacked these scopes?
« Reply #300 on: July 31, 2015, 11:40:31 pm »
Congratulations on your new scope and your "upgrade"
Isn't it amazing when you use the big screen for the first time.
Agreed, but just possibly toooo big... dread to think about how the 4000X and 6000X are with the same physical screen size but lower resolution. I can see why Mike reckons the 6+" is OK, because they don't really use the XGA screen to its best advantage when scaled up to 12". 8 or 10" might've been a really nice size.
Replaced the scope stack above the main monitor with this one now. I've gained another 3-4" of depth on the desk as everything can be pushed back now.
Offline nctnico
« Reply #301 on: August 01, 2015, 05:50:42 pm »
I have a DSO7104A and I realy like the big screen. Finally a scope where you can have 2 traces on top of eachother without cramming the screen contents. Mine was appearantly hacked by the previous owner; I could enable the circular segmented memory option by entering a bogus key.
Offline HighVoltage
« Reply #302 on: August 01, 2015, 08:58:02 pm »
It is also a little surprise to me, that the 6000 series 1GHz scope has a higher list price on the keysight store than the 7000 series 1 GHz.
May be it is the MSO option, that makes the difference
Offline nctnico
« Reply #303 on: August 01, 2015, 09:40:17 pm »
The MSO option probably makes the price different. If you look carefully on Ebay you can buy the MSO probes in mint condition for less than $300.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #304 on: August 01, 2015, 09:45:54 pm »
You can also occasionally find old 1650 or 1651 logic analysers with 5 or 2 probes for that sort of money.
Day Job: Mostly LEDs
The following users thanked this post: Orange
Offline Howardlong
« Reply #305 on: August 01, 2015, 11:29:35 pm »
I already had two sets of probes from the 54622D and 54642D that I have, so that wasn't a problem for me.
Unfortunately I have had to travel to Hong Kong at short notice so I won't be able to do any nerding about until I return on Sunday night.
Offline Howardlong
« Reply #306 on: August 02, 2015, 12:02:08 am »
I also already had three 10073C 500MHz passive probes. There's a fella selling brand new ones on ebay at the moment for $60, that's pretty darned good for a branded 500MHz probe. I bought three, but was sent four :-)
They are totally new, in original packaging, with standard accessories.
http://www.ebay.co.uk/itm/191634169278?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Offline knotlogic
  • Country: sg
« Reply #307 on: August 21, 2015, 07:08:15 am »
Has anyone tried this out with a 5000 series scope?  Any luck?
« Reply #308 on: August 21, 2015, 08:06:35 am »
The software is the same for 5000,6000 and 7000 so should work.
Offline knotlogic
  • Country: sg
« Reply #309 on: August 21, 2015, 08:27:06 am »
Well.... Should is not quite the same as does...  Not wanting to start an argument or anything.  Just that I'm interesting in picking up a scope and the 6000s are pricey, so it'd be good to find out now rather than later...  :D
Offline Berni
  • Country: si
« Reply #310 on: August 21, 2015, 09:05:10 am »
Relax the firmware update file on the Keysight website is the same for both 5000 and 6000. The 7000 even has a separate firmware file and it still works on it.
http://www.keysight.com/main/software.jspx?ckey=2211091&lc=eng&cc=SI&nid=-32924.0.00&id=2211091
Offline HighVoltage
« Reply #311 on: August 21, 2015, 10:05:30 am »
You "should" be happy, that that you get such valuable advise here at this forum.
I bought a used 7000A and it did not work at all, but there was may be something wrong with the scope. I sold it again and got the 7000B series and it worked extremely well.
Offline Howardlong
« Reply #312 on: August 21, 2015, 02:37:22 pm »
There's a French Youtube vid showing a bloke liberating a 5000.
Offline knotlogic
  • Country: sg
« Reply #313 on: August 21, 2015, 04:27:10 pm »
Oh believe me, I am.  The only thing I am not "quite" so happy about is I  never found this place years ago.  ;D
Thanks!  That's more than I could hope for really.  Even without being able to speak French I think I understood what he was saying.  Now all I need to do is find one...
I am curious though, what *are* the differences between the 5000 and 6000 series?  It seems they have the same performance specs, only that the 6000 goes all the way up to 1 GHz and has the MSO option.
« Reply #314 on: August 21, 2015, 05:12:16 pm »
Mostly MSO, I think maybe also  the physical size is less deep - check the datasheets.
When choosing remember that decodes are only available on 4-channel models.
Offline knotlogic
  • Country: sg
« Reply #315 on: August 26, 2015, 04:11:27 pm »
Yep the 5000s are definitely less deep.  I'm surprised that the MSO option would need that much more space on the 6000.  Or maybe the 1 GHz units need some of it too.  :-//
So this is one of the rare times I've been lucky.  I found someone with one to sell.  The catch is he can't complete the self test.  Apparently there's a keypad test, and the last item is the calibration protect switch on the back.  He doesn't know what that switch does and isn't comfortable flipping it.
What *does* that switch do?  My understanding is that it just locks out the option to do a user cal from the service menu.
Also, what's the test flow like for the self test?  Is there any useful information that comes up before hitting the keypad test?  I'm on the fence on this one.  It's a nice scope to have, but I'm not confident of handling any repairs should it need any.
« Last Edit: August 26, 2015, 04:13:33 pm by knotlogic »
Offline wreeve
    • embedded u systems limited
« Reply #316 on: August 26, 2015, 05:41:13 pm »
Yes it just locks out the user cal. Ironically I had to give it a good few actions to get it working on my 'scope! Guess it gets little use!
Offline knotlogic
  • Country: sg
« Reply #317 on: September 01, 2015, 02:32:20 pm »
Uh, anyone have a copy of the v06.16.001 firmware for the 5000? Or could point me in the direction of it.  The only version I could find on the website is v6.20.
Offline dolphin42
« Reply #318 on: November 28, 2015, 08:18:05 am »
So, having successfully fiddled with my scope and turned (most) features on, I have just one question: is memMAX available from the "enter license" end of the hack, or is that one only available from the "service menu" hack?
and if it is available from the license end, what's the mnemonic?
Offline Howardlong
« Reply #319 on: November 28, 2015, 08:38:00 am »
My understanding was that the 8M points was automatically enabled with firmware after a certain version some time ago.
I'm away in Hong Kong until Sunday, I can check for you upon my return if no one else responds in the meantime.
« Reply #320 on: November 28, 2015, 08:40:39 am »
Nice, hope you find some goodies Howard.
« Reply #321 on: November 28, 2015, 08:58:15 am »
If the scope already has 8M that is the maximum - this became standard not long after the scope was released.
Offline Berni
  • Country: si
« Reply #322 on: November 28, 2015, 10:20:51 am »
No the 8M memory still needs a license. Just the scopes sold after a certain date all had the license on for free. I had to enter a license for it on mine.
Offline dolphin42
« Reply #323 on: November 28, 2015, 10:33:34 am »
Right then, well I have the 8M already. Guess "mission accomplished". :)
Offline Howardlong
« Reply #324 on: November 28, 2015, 10:49:43 am »
Only there for eight hours to pick up some parts for a production run next week that went missing somewhere in the logistics ether. Might pop over to Pacific Place if I get chance to take in Mike's handiwork.
