Author Topic: Agilent MSO 5000/6000/7000 - anyone hacked these scopes?  (Read 284198 times)
0 Members and 27 Guests are viewing this topic.
Offline Howardlong
Re: Agilent MSO 5000/6000/7000 - anyone hacked these scopes?
« Reply #600 on: August 25, 2020, 02:53:32 pm »
Not sure how many folks are using these scopes nowadays, but wanted to share a few notes on the serial decodes:
I have an MSO7104B, it remains my go to scope on the bench, despite having a number of other more modern and "more capable" scopes around. Why? It has the fastest and most usable UI, fast boot time, and a nice big telly too.
Note there's a limit on the SPI decode speed as well, it falls over at about 35MHz, spec is to 25MHz.
Offline HighVoltage
« Reply #601 on: August 26, 2020, 06:19:49 am »
Same here with me. I have two 7000 series scopes and they are my favorite scopes every day.
The 6000X series scope is not used much.
Offline smetankin
  • Country: ru
« Reply #602 on: September 16, 2020, 07:47:56 pm »
Hi everyone. Wish to unlock 7k series scope, but can`t find jzp tools to Win based system.
Does anyone have this app? Tnx...
Offline HighVoltage
« Reply #603 on: September 16, 2020, 09:41:42 pm »
Hello and welcome to the eevblog forum
The easiest way to unlock the 7000 series scope is through the service mode.
The detailed description is earlier in this thread.
Offline smetankin
  • Country: ru
« Reply #604 on: September 17, 2020, 03:44:09 pm »
I`m so unlucky?  :)
Offline Miek
« Reply #605 on: September 17, 2020, 04:16:34 pm »
Just in case anyone does still need it, I've got a copy of agltzip here: https://github.com/miek/agltzip (step back one commit for the original version)
« Last Edit: September 17, 2020, 04:31:10 pm by Miek »
The following users thanked this post: Orange
Offline Orange
« Reply #606 on: September 17, 2020, 04:54:14 pm »
Agilent JZP tools
Windows version 0.2
A set of tools for Agilent JZP compression format.
A well-known LZSS algorithm with custom header is used.
Compression speed is far from being optimal, compressing a 10MiB file takes around 1 minute on i7 machine, but it works :)
Bugfixed compressor produces same files as originals now.
Example:
unjzp sys.jzp sys.bin sys_rev.txt
packjzp sys.bin sys_new.jzp sys_rev.txt
sys_new.jzp will match sys.jzp exactly
« Last Edit: September 17, 2020, 05:11:09 pm by Orange »
The following users thanked this post: egonotto, Miek, wp_wp
Offline Orange
« Reply #607 on: September 17, 2020, 06:51:06 pm »
DSO 7000A/B firmware V6.16
Part 1
This is the patched version which allows you to enter the options without the key
The following users thanked this post: egonotto, analogRF
Offline Orange
« Reply #608 on: September 17, 2020, 06:51:50 pm »
Part 2
Offline Orange
« Reply #609 on: September 17, 2020, 07:14:22 pm »
DSO 7000A/B firmware V6.20
Part 1
The following users thanked this post: egonotto, analogRF, smetankin
Offline Orange
« Reply #610 on: September 17, 2020, 07:15:10 pm »
Part 2
The following users thanked this post: egonotto, HighVoltage, analogRF, smetankin
Offline smetankin
  • Country: ru
« Reply #611 on: September 18, 2020, 08:24:26 pm »
Orange, awesome, thanks a lot.  :-+
Offline HighVoltage
« Reply #612 on: September 20, 2020, 12:06:26 pm »
I am still running the scope on FW 7 without any problems
« Last Edit: October 09, 2020, 03:37:01 pm by HighVoltage »
Offline TheSteve
  • Living the Dream
« Reply #613 on: September 25, 2020, 08:18:33 pm »
Congrats - that is a very nice scope!
This thread deals with with the older generation of scopes though, the hacks mentioned don't apply the "X" series.
VE7FM
Offline tv84
  • Country: pt
« Reply #614 on: October 04, 2020, 05:49:36 pm »
With the help of abyrvalg here is the end to option patching also on these old scopes (5000/6000/7000).
The license format is:
FEATURE segmentedMem agilent 1.0 permanent uncounted 000000000000 HOSTID=ID_STRING=001122334455
where 001122334455 is your MAC address.
The following users thanked this post: egonotto, ps, analogRF, zrq
Offline abyrvalg
« Reply #615 on: October 04, 2020, 08:08:06 pm »
short name -> lmcrypt name:
ALL  all_licenses_on
REM remove_all_licenses
FMS factoryMso
MSO mso / mso_6000_low / mso_6000_high - depending on model
001 am1M / am1M_6000_low / am1M_6000_high
002 am2M / am2M_6000_low / am2M_6000_high
004 ...
008 ...
016
032
064
128
256
512
AMM amMax
FPG fpgaProbe
LSS lsSerDecode
AMS amSerDecode
CAN canTrigger
SEC secure - stay away!!!
BAT battery
ALT fpgaAltera
FRS frSerDecode
PWR power
232 232SerDecode
DSW distributor
SGM segmentedMem
LMT lmtMaskTest
TEL telMaskTest
1MV 1mvChanScale
FRC frCompliance
MST measStats
E00 enhance00
SND i2sSerDecode
FLX flxSerDecode
DIS distDemo
TOM tomoTherapy
553 1553SerDecode
CIR segCircular
The following users thanked this post: ps
Offline swperk
« Reply #616 on: October 08, 2020, 03:12:24 am »
@Erik: Good job!
Does anyone know the meaning of the "Unsealed Instrument" warning? Does it affect operation of the scope in any way? What is it about the hack that makes the scope display this message, and is there any way to eliminate it?
Thanks,
Stan
Offline HighVoltage
« Reply #617 on: October 08, 2020, 07:14:30 am »
The 7000 series scope is very easy to be put in to service mode
« Last Edit: October 09, 2020, 03:35:44 pm by HighVoltage »
The following users thanked this post: mlloyd1
Offline VooDust
« Reply #618 on: October 08, 2020, 09:11:41 am »
So I can buy the 1 GHz edition and hack it to 6 GHz?
Offline HighVoltage
« Reply #619 on: October 08, 2020, 10:05:08 am »
The 6000 Series scope is my every day scope
« Last Edit: October 09, 2020, 03:34:14 pm by HighVoltage »
Offline tv84
  • Country: pt
« Reply #620 on: October 08, 2020, 10:23:31 am »
Keysight protects the system by enabling a "seal flag" which prevents changes to the licensing, command line and other settings.
The hack that is public overrides that "seal" setting in a global way. By doing so, when the scope reads the status of the "seal" for any kind of operation, you get an unsealed setting and the change is allowed.
IMHO Keysight wanted to be sure that the config is "sealed" before shipping and, as such, developed that msg warning.
That state shouldn't create any harm unless people (or a bug) do operations that shouldn't be done that, in normal circumstances, would be barred by the "sealing".
BTW, all this talk about the X-models is OT in this thread!
Offline wolfy007
« Reply #621 on: October 09, 2020, 06:21:59 am »
Dont suppose this would work on DSO9000A series?
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
« Reply #622 on: October 09, 2020, 03:37:24 pm »
Totally different operating systems.
The following users thanked this post: wolfy007
Offline jjoonathan
« Reply #623 on: October 09, 2020, 04:56:12 pm »
(thread goes quiet)
If you don't move he can't see you!
Offline wolfy007
« Reply #624 on: October 09, 2020, 05:33:31 pm »
(thread goes quiet)
 :-DD
For me DSO9000A is EOL now, so I guess only way to upgrade it now is to hack it...   :-//
