Had a quick play with a hack abyrvalg sent to try enabling decodes on a 2-channel scope but no joy yet (gives "Option not supported" when it boots)
Had a look for license names in the sys6000.bin image :
AFAICS the list is the same as the 7000 one posted earlier
Tried ALL, Which enables some demos - these are for use in conjunction with a demo board - ISTR having this when I had a scope on loan before buying mine.
When enabled, licnse info shows FPG*,LSS*,AMS*,CAN*,ALT*,232,FRC*,SND*,FLX*,553*
I had a look insode my MSO6012A, and apart from the front-end and ch3/4 ASICs it looks the same - same FPGA, so might be viable to enable decodes on 2ch models.
Front-end is obviously different from the 6034. Interestingly the trigger channel uses the same front-end as the analogue channels.
