Author Topic: Agilent MSO 5000/6000/7000 - anyone hacked these scopes?  (Read 284094 times)
0 Members and 18 Guests are viewing this topic.
Offline HighVoltage
Re: Agilent MSO 5000/6000/7000 - anyone hacked these scopes?
« Reply #475 on: July 28, 2016, 07:59:28 pm »
OK, I got my DSOX6000A today and tried telnet.
I am getting the login screen the same way as on my 7000 series scope.
But ...
 infiniivision / skywalker1977
does NOT work
« Last Edit: August 08, 2016, 11:31:48 pm by HighVoltage »
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #476 on: July 28, 2016, 08:45:41 pm »
There is a different login on the x series - it's mentioned in the 2000/3000X thread somewhere ( but doesn't work on the MSOX30104T)
Day Job: Mostly LEDs
Offline HighVoltage
« Reply #477 on: August 08, 2016, 10:53:22 pm »
With a BIG THANK YOU to memset, I was able to hack my DSOX6004A partially so far.
This DSO-X-6004A had all options installed from the factory, except:
Limited to 1 GHz and no MSO
I don't care too much about the MSO feature, but I really would like to have the 6 GHz activated.
And here is the problem, I am getting it only modified to 2.5 GHz
The procedure is similar to the 3000X series and you can find everything here:
https://www.eevblog.com/forum/testgear/dsox2000-and-3000-series-licence-have-anyone-tried-to-hack-that-scope/msg989301/#msg989301
The file structure is a little different and on the 6000X series, the startup folder is hiding in:
\System\startup
Log in with telnet and then copy the lnk file from USB to this startup folder works well.
Here is a picture of my normal setup (No modification)
Offline HighVoltage
« Reply #478 on: August 08, 2016, 10:56:32 pm »
Here is the change to 2.5 GHz and MSO only
infiniivsion_ext.lnk:
64#\System\infiniivision\infiniivisionlauncher.exe -l MSO -l BW250
Interestingly, it adds the MEMUP, SGM, ADVMATH without having it in the lnk file
MSO and Bandwidth to 2.5 GHz work well
« Last Edit: August 08, 2016, 10:58:54 pm by HighVoltage »
Offline HighVoltage
« Reply #479 on: August 08, 2016, 11:04:25 pm »
And here is my Full Options lnk file
254#\System\infiniivision\infiniivisionlauncher.exe -l MSO -l BW250 -l FPGAX -l MEMUP -l EMBD -l AUTO -l FLEX -l PWR -l COMP -l SMG -l MASK -l AUDIO -l EDK -l WAVEGEN -l AERO -l VID -l ADVMATH -l DVMCTR -l USBFL -l USBH -l USBSQ -l SENSOR -l CANFD -l JITTER
But, no matter what I try, the Bandwidth will not go higher than 2.5 GHz
BW400 not working
BW600 not working
BW6, BW6000 BW60 also not working
Anyone here have an idea of what to try?
But having it at 2.5 GHz is already really great.
Seeing the MTB at 100 ps resolution and working for the first time is more than great.
Thanks again memset !
Offline TheSteve
  • Living the Dream
« Reply #480 on: August 08, 2016, 11:10:29 pm »
Any chance adding multiple bw license options might help such as: -l BW250 -l BW400 -l BW600
VE7FM
Offline HighVoltage
« Reply #481 on: August 08, 2016, 11:19:47 pm »
TheSteve,
What a great idea, thank you!
4 GHz is working with the combination "-l BW250 -l BW400"
Now lets try 6 GHz ....
Offline memset
  • Country: ru
« Reply #482 on: August 08, 2016, 11:29:05 pm »
Nice catch TheSteve! I think 6 should work this way too.
Offline HighVoltage
« Reply #483 on: August 08, 2016, 11:30:26 pm »
Even better:
6GHz is working perfectly!
But the smallest Time Base is staying at 100 ps, same as with 2.5 GHz and 4 GHz
The original smallest time base was 500 ps at the 1 GHz setting.
91#\System\infiniivision\infiniivisionlauncher.exe -l MSO -l BW250 -l BW250 -l BW400 -l BW600
Now lets add all the other options again
The following users thanked this post: swperk
Offline TheSteve
  • Living the Dream
« Reply #484 on: August 08, 2016, 11:31:05 pm »
If you thought 1 GHz active probes were expensive, just think of the money you can spend now!
VE7FM
Offline memset
  • Country: ru
« Reply #485 on: August 08, 2016, 11:33:40 pm »
250 option used twice? Also don't forget not to exceed 260 byte file length in total.
Offline HighVoltage
« Reply #486 on: August 08, 2016, 11:59:56 pm »
Ahhh!
When I added all options again, I was at 272 bytes
Removed: MEMUP, SGM, ADVMATH (since they showed up anyways) and made a last lnk file
246#\System\infiniivision\infiniivisionlauncher.exe -l MSO  -l BW250 -l BW400 -l BW600 -l FPGAX -l EMBD -l AUTO -l FLEX -l PWR -l COMP -l MASK -l AUDIO -l EDK -l WAVEGEN -l AERO -l VID -l DVMCTR -l USBFL -l USBH -l USBSQ -l SENSOR -l CANFD -l JITTER
All working!
But I am still surprised that 100 ps is the smallest time base setting.
Thank you all
This might be the first hacked 6000X series scope?
Offline HighVoltage
« Reply #487 on: August 09, 2016, 12:14:46 am »
I know, oh my!
I have a few 1.5 GHz differential and active probes.
Now the hunt starts for 6 GHz probes.
Plus it seems I need a faster pulse gen.
For the fist time this 450 ps pulse is too slow.
Offline Berni
  • Country: si
« Reply #488 on: August 09, 2016, 05:23:15 am »
Nice one :-+. That is a surprisingly easy hack once you know what to do.
Hope you have a deep wallet for those 6GHz probes indeed. I got my hands on a presumably broken one with the plastic case missing but when plugging it in it worked!
Oh and by the way getting a pulse fast enough to push 6GHz to its limit is not easy at all. The best i could get out of a jim williams pulse circuit is 150ps. Only way i got to generating signals this fast is my boatanchor 20GHz RF synthesizer.
Offline Howardlong
« Reply #489 on: August 09, 2016, 06:17:37 am »
I know, oh my!
If you can deal with the loading, 54006a lo-z probes turn up on ebay quite regularly, although as I write there's slim pickings. Make sure they have all parts including the SMA cable (itself worth a few bob), through capacitor, reassuringly branded BNC-SMA, walking sticks and spare resistors.
Another option although it's only good to 2.5GHz is the 1152A. Again, check for all the bits & pieces, and check it's compatible with your scope, some of these probes dropped off the supported list of newer Agisights, but you can work around that, either with a resistor if you open up the probe or by using an external board.
https://www.eevblog.com/forum/testgear/agilent-mso-500060007000-anyone-hacked-these-scopes/msg868073/#msg868073
http://www.alciom.com/images/stories/downloads/powerprobe%201a.pdf
Offline rx8pilot
« Reply #490 on: August 09, 2016, 08:12:01 am »
My 6ghz X6000 only goes to 100ps. I guess that is normal, but I was thinking it should be 50ps.
Sent from my horrible mobile....
Offline HighVoltage
« Reply #491 on: August 09, 2016, 08:30:59 am »
Thank Carlos, you for confirming this.
It is indeed interesting:
1 GHz = 500 ps
2.5 GHz = 100 ps
4 GHz = 100 ps
6 GHz = 100 ps
I also expected 50 ps as a smallest setting for the time base.
Yes, time to look for probes.
But since not to many companies buy these probes and put them on a second market, I might have to wait a long time.
Offline plesa
« Reply #492 on: August 09, 2016, 06:55:42 pm »
Wow, nice hack, I hope it will makes 6kX series more attractive:)
Offline HighVoltage
« Reply #493 on: August 09, 2016, 06:59:11 pm »
Just for completeness:
I used the scope all day long today and had no issues at all.
Then I removed the .lnk file and updated the FW to 06.12.2016010702
And then I reinstalled the .lnk file.
All working as expected.
Offline rx8pilot
« Reply #494 on: August 09, 2016, 07:13:22 pm »
I suspect it will take a long time for me to acquire the appropriate probes for this scope. So far I only have 4x 500Mhz 10:1 passives and two 100mhz differential amplifiers.
Needed:
2x DC current probes >30Mhz >30A continuous
4x 2.5Ghz single ended active probes for daily use
2x 6Ghz diff probes
1x HV differential low frequency probes for AC power analysis.
Not cheap, but at least there is a business to justify the expense. Looking for deals, but can only wait so long. As soon as I am able to start on my next design, it will define what probes are needed first. The scope is like a camera without a lens. A dedicated photographer always wants a huge variety of lenses to capture the moment just right. Some lenses rarely get used.
Offline Howardlong
« Reply #495 on: August 09, 2016, 09:37:53 pm »
YMMV of course, but 99% the time I still probe with light-weight miniature passive Hi-Z probes. Maybe once a week or two I break out the expensive probes. These probes simply tend to be fiddly to set up logistically, either because you need to solder in a probe point or because there is usually no concept of just clipping onto a signal, you have to either hand hold it or set up a clamp/balancing jig. Some of these probes also include expensive consumables like tip resistors: as an example, this'll make you cringe, $44 for _one_ resistor tip, a diff probe needs two:
http://www.ebay.co.uk/itm/01131-62102-01131-62107-for-E2658A-E2663A-E2668A-E2669A-E2675A-E2676A-/231422124137
Offline rx8pilot
« Reply #496 on: August 09, 2016, 10:06:06 pm »
There is nothing inexpensive at this bandwidth, thats for sure. It's not just technically challenging, but also generally associated with business which adds up to big prices.
Offline Berni
  • Country: si
« Reply #497 on: August 10, 2016, 05:23:49 am »
Yeah most of the time the fancy active probes sit in a box. But when a need for one comes up they save the day. Yesterday i used one of my probes to check if a 330MHz differential MIPI clock had good integrity (Tiny signal, picky loading, commonmode crap etc makes it difficult to do with a regular probe), before that the probes was last used months ago id guess.
The diff probe i have makes use of regular trough hole resistors by giving you a coax to female header adapter along with a pack of resistors. This means i can use any cheep resistor as long as the pin is the same thickness. Downside tho is that the resistor pins are too thick for fine pitch chips.
Offline HighVoltage
« Reply #498 on: August 10, 2016, 06:55:25 am »
What model probe is this?
Can you show a picture of this ?
Offline Berni
  • Country: si
« Reply #499 on: August 10, 2016, 07:59:02 am »
It is part of the "E2669A InfiniiMax Differential/Single-ended Connectivity Kit" that i got it with the Agilent 1131A Diff probe(3.5GHz), its missing parts but the one of interest is the 3rd cable from top to bottom in the photo.
http://www.keysight.com/en/pd-339402-pn-E2669A/infiniimax-differential-connectivity-kit?cc=SI&lc=eng
The other one above is is direct solder in using some super tiny trough hole resistors that actually have a square body instead of round. Those probably work for 0.5mm pitch chips but i never used it.
