Hi All
hope you can shed some light on this for me.
just received my rigol DP832A (bloody noisy fan)
just checking measurements to see how it performs.
now for example (as the pictures will show) if i set the output to 30.111 volts, the top line shows 30.120 (weird) and the set at the bottom is 30.111 ( to be expected)
on cheking the output with my eevblog meter it is reading the correct voltage withing a few milivolts, yet the voltage displayed at the top is showing 9mv more than it should.
is this normal?
cheers
steve
P.S. is there anyway to turn the fan off while not under load?
