Author Topic: SOLVED - Rigol MSO5000 firmware reset without UI?  (Read 1475 times)
Offline HarvsTopic starter
« on: April 30, 2019, 09:12:55 am »
I've got a Rigol MSO5000 that today decided to fail on start halfway through the day. Gets to the UI, and I can get a single button push in before the UI locks up. I haven't used the ethernet before, but assuming it would be DHCP by default, it doesn't show up in an ip scan.
At a guess it would seem like a file has been corrupted, but hard to be sure? Seems like it locks up as it's finalising the boot process.
It's hacked and I have the /rigol/data folder backed up.  It's not very old, so would normally be a warranty job, but it's pretty obvious it has a whole lot of stuff enabled that I didn't buy keys for.
So anyway is there a way to reset or reload the firmware without the normal menu access and without opening the case?  Or is it a matter of cracking it open to get to the uart?
Sorry if there's something I've missed with my searching and this has already be answered somewhere.
« Last Edit: April 30, 2019, 10:18:58 am by Harvs »
Re: Rigol MSO5000 firmware reset without UI?
« Reply #1 on: April 30, 2019, 10:18:39 am »
Found it, I knew it would be in there somewhere!
https://www.eevblog.com/forum/testgear/hacking-the-rigol-mso5000-series-oscilloscopes/msg2250807/#msg2250807
Thanks to everyone who contributes to this great wealth of info.  Scopes all good again.
