The GUI Part of the Software is java, there is also a server part that is not written in Java. Some parts of the Software are missing in the Firmware update.
Some details from a running system:
[root@Linux /root]$dmesg
Linux version 2.4.19-rmk7-ads5 (sreynard@elgato2.soco.agilent.com) (gcc version 2.95.2 19991024 (release)) #30 Wed Apr 28 13:36:58 UTC 2004
CPU: StrongARM-1110 revision 9
Machine: ADS GraphicsMaster
Warning: bad configuration page, trying to continue
On node 0 totalpages: 8192
zone(0): 256 pages.
zone(1): 7936 pages.
zone(2): 0 pages.
On node 1 totalpages: 8192
zone(0): 256 pages.
zone(2): 0 pages.
Kernel command line: console=tty1 mem=32m@0xC0000000 mem=32m@0xC8000000 rw ramdisk_size=8192 initrd=0xC0800000,3m root=/dev/ram sa1100_pcmcia_opts=sock:0(speed_io:100,fast_mode),sock:1(speed_io:80)
Relocating machine vectors to 0xffff0000
Console: colour dummy device 80x30
Calibrating delay loop... 137.21 BogoMIPS
Memory: 32MB 32MB = 64MB total
Memory: 59552KB available (1716K code, 360K data, 88K init)
Dentry cache hash table entries: 8192 (order: 4, 65536 bytes)
Inode cache hash table entries: 4096 (order: 3, 32768 bytes)
Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
Buffer-cache hash table entries: 4096 (order: 2, 16384 bytes)
Page-cache hash table entries: 16384 (order: 4, 65536 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
sa1111_pcibuf: initializing SA-1111 DMA workaround
SA1111 Microprocessor Companion Chip: silicon revision 1, metal revision 1
Starting kswapd
JFFS version 1.0, (C) 1999, 2000 Axis Communications AB
JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB.
ttyS0 at I/O 0xf0100000 (irq = 50) is a 16550A
ttyS1 at I/O 0xf0120000 (irq = 51) is a 16550A
ttyS2 at I/O 0xf0140000 (irq = 52) is a 16550A
ttyS3 at I/O 0xf0160000 (irq = 54) is a 16550A
ttySA0 at MEM 0x80050000 (irq = 17) is a SA1100
ttySA1 at MEM 0x80010000 (irq = 15) is a SA1100
ttySA2 at MEM 0x80030000 (irq = 16) is a SA1100
Console: switching to colour frame buffer device 80x30
initialize_kbd: Keyboard reset failed, no ACK
Keyboard timed out[1]
keyboard: Timeout - AT keyboard not present?
pty: 256 Unix98 ptys configured
UCB1200 generic module installed
ucb1200 touch screen driver initialized
ucb1200 adc driver initialized
UCB1200 audio driver version 2.2 initialized
UCB1200 audio driver Click-Avoid patch: TT <tthaele@papenmeier.de>
UCB1200 Mixer driver version 0.1 initialized. TT <tthaele@papenmeier.de>
smartio driver initialized. version 1.10, date:28-Jun-2002
SmartIO ID : 0x5002
Device Version : 6(0x36)
Device Type : 0x8535
SA1100 Real Time Clock driver v1.00
Uniform Multi-Platform E-IDE driver Revision: 6.31
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
smc9194.c:v0.14 12/15/00 by Erik Stahlman (erik@vt.edu)
eth0: SMC91C96(r:9) at 0xf00e0000 IRQ:58 INTF:TP MEM:6144b ADDR: 00:60:0c:00:4c:5f
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
loop: loaded (max 8 devices)
PPP generic driver version 2.4.2
Sound: SA1111 UDA1341: dsp id 3 mixer id 0
SA1111 audio out: SA-1111 SAC DMA channel 6 in use
DMA request for SAC output failed
physmap flash device: 4000000 at 8000000
Physically mapped flash: Found 2 x16 devices at 0x2000000 in 32-bit mode
0: offset=0x0,size=0x40000,blocks=128
1: offset=0x2000000,size=0x40000,blocks=128
Using buffer write method
SA1100 flash: probing 32-bit flash bus
SA1100 flash: Found 2 x16 devices at 0x2000000 in 32-bit mode
Using static partition definition
Creating 3 MTD partitions on "SA1100 flash":
0x00000000-0x00100000 : "zImage"
0x00100000-0x00400000 : "ramdisk.gz"
0x00400000-0x04000000 : "User FS"
Linux Kernel Card Services 3.1.22
options: [pm]
SA-1100 PCMCIA (CS release 3.1.22)
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
hcd/ohci-sa1111.c: starting SA-1111 OHCI USB Controller
hcd/ohci-sa1111.c: ohci-hcd (SA-1111) at 0xf4000400, irq 109
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
hub.c: 1 port detected
usb.c: registered new driver hiddev
hid-core.c: v1.8.1 Andreas Gal, Vojtech Pavlik <vojtech@suse.cz>
hid-core.c: USB HID support drivers
mice: PS/2 mouse device common for all mice
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 4096 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NetWinder Floating Point Emulator V0.95 (c) 1998-1999 Rebel.com
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 3072K
EXT2-fs warning: checktime reached, running e2fsck is recommended
VFS: Mounted root (ext2 filesystem).
Freeing init memory: 88K
hub.c: USB new device connect on bus1/1, assigned device number 2
hub.c: 4 ports detected
enable_irq(114) unbalanced from c032558c
Trying to free nonexistent resource <ce8a6000-ce8a600f>
hda: SILICONSYSTEMS INC 128MB, ATA DISK drive
ide0 at 0xce8a6000-0xce8a6007,0xce8a600e on irq 114
hda: 254208 sectors (130 MB) w/0KiB Cache, CHS=993/8/32
Partition check:
hda: hda1
ide_cs: hda: Vcc = 3.3, Vpp = 0.0
hda: hda1
hda: hda1
VFS: Can't find ext2 filesystem on dev ide0(3,1).
hda: hda1
hda: hda1
cramfs: wrong magic
hda: hda1
hda: hda1
hda: hda1
hda: hda1
hda: hda1
hda: hda1
cramfs: wrong magic
hda: hda1
hda: hda1
AVR driver initialized. version 1.1, date:Aug 6 2004
[root@Linux /proc]$cat /proc/cpuinfo
Processor : StrongARM-1110 rev 9 (v4l)
BogoMIPS : 137.21
Features : swp half 26bit fastmult
Hardware : ADS GraphicsMaster
Revision : 0000
Serial : 0000000000000000
[root@Linux /proc]$
I think this module is used to reprogram a avr controller in the device
[root@Linux /root]$lsmod
Module Size Used by
avrprog 5416 0 (unused)
[root@Linux /root]$
[root@Linux /root]$cat /proc/interrupts
0: 42792 ADS_ext_IRQ
1: 0 sleep
11: 0 GPIO 11-27
12: 1 LCD
17: 1224 serial_sa1100
26: 62869 timer
27: 0 rtc timer
30: 2 rtc 1Hz
31: 0 rtc Alrm
49: 223 SA1111
50: 40201 serial
52: 982 serial
54: 191 serial
57: 0 UCB1200
58: 1059 eth0
63: 8 sio
87: 0 keyboard
97: 0 SA1111 audio out
98: 0 SA1111 audio in
99: 0 SA1111 audio out
100: 0 SA1111 audio in
109: 24 ohci-hcd
114: 240 ide0
116: 0 SA1111 PCMCIA card detect
117: 0 SA1111 CF card detect
118: 0 SA1111 PCMCIA BVD1
119: 0 SA1111 CF BVD1
Err: 0
[root@Linux /root]$
[root@Linux /root]$ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 1.1 0.8 1384 544 ? S Feb13 0:07 init
root 2 0.0 0.0 0 0 ? SW Feb13 0:00 [keventd]
root 3 0.0 0.0 0 0 ? SWN Feb13 0:00 [ksoftirqd_CPU0]
root 4 0.0 0.0 0 0 ? SW Feb13 0:00 [kswapd]
root 5 0.0 0.0 0 0 ? SW Feb13 0:00 [bdflush]
root 6 0.0 0.0 0 0 ? SW Feb13 0:00 [kupdated]
root 7 0.0 0.0 0 0 ? SW Feb13 0:00 [mtdblockd]
root 8 0.0 0.0 0 0 ? SW Feb13 0:00 [khubd]
root 40 0.0 0.0 0 0 ? SWN Feb13 0:00 [jffs2_gcd_mtd3]
root 56 0.0 1.1 1480 744 ? S Feb13 0:00 /sbin/cardmgr -f
root 587 0.0 1.0 1568 644 ? S Feb13 0:00 dhcpcd -DH -t 10
root 610 0.0 0.8 1680 544 ? S Feb13 0:00 syslogd -m 0
bin 636 0.0 0.7 1456 444 ? S Feb13 0:00 [portmap]
root 666 0.0 1.0 1592 644 ? S Feb13 0:00 inetd
root 679 0.0 0.8 1704 544 ? S Feb13 0:00 /bin/sh /etc/rc.d/rc3.d/S51timeUpdate.sh start
root 680 0.0 1.2 1788 772 ? S Feb13 0:00 /bin/bash /flash/elgato/utils/keepTimeUpdated
root 681 0.0 0.5 1672 336 ? S Feb13 0:00 sleep 1200
root 701 0.8 11.4 93644 7176 ? S Feb13 0:05 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 710 0.0 0.7 1572 476 tty1 S Feb13 0:00 /sbin/getty 38400 tty1
root 711 0.0 0.7 1572 484 ttyS/ttySA0 S Feb13 0:00 /sbin/getty -L ttyS0 38400 vt100
root 712 0.0 1.2 1796 808 ? S Feb13 0:00 /bin/bash /root/catch_sleep.sh
root 724 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 725 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 726 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 727 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 729 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 730 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 731 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 732 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 738 0.2 11.4 93644 7176 ? S Feb13 0:01 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 751 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 752 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 753 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 754 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 755 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 756 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 757 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 758 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 759 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 774 1.1 22.2 18540 13968 tty2 S Feb13 0:07 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 776 0.0 22.2 18540 13968 tty2 S Feb13 0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 777 0.0 22.2 18540 13968 tty2 S Feb13 0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 778 0.0 22.2 18540 13968 tty2 S Feb13 0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 779 0.0 22.2 18540 13968 tty2 S Feb13 0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 780 9.9 22.2 18540 13968 tty2 S Feb13 1:02 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 781 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 782 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 783 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 784 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 785 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 786 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 787 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 788 0.0 22.2 18540 13968 tty2 S Feb13 0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 789 0.0 22.2 18540 13968 tty2 S Feb13 0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 790 0.0 22.2 18540 13968 tty2 S Feb13 0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 791 0.0 22.2 18540 13968 tty2 S Feb13 0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 792 0.0 22.2 18540 13968 tty2 S Feb13 0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 795 0.2 22.2 18540 13968 tty2 S Feb13 0:01 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 798 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 799 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 800 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 801 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 802 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 803 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 804 0.7 11.4 93644 7176 ? S Feb13 0:04 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 805 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 806 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 807 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 808 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 809 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 810 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 811 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 812 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 813 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 814 0.0 11.4 93644 7176 ? S Feb13 0:00 /flash/egServer/elgato -xaemon -o /dev/ttyS0 -e /dev/ttyS0
root 819 0.0 22.2 18540 13968 tty2 S Feb13 0:00 /flash/siege/bin/_siege -Xmx23m -DlocalAddress=127.0.0.1 -Dserver=127.0.0.1 -DLogger.level=2 -
root 824 0.0 1.3 1956 848 ? S Feb13 0:00 in.telnetd
root 825 0.0 1.5 1824 948 pts/0 S Feb13 0:00 -bash
root 839 0.0 1.3 2736 876 pts/0 R 00:03 0:00 ps aux
[root@Linux /root]$
The serial port /dev/ttyS/ttySA0 is used for a serial console, and elgato is using ttyS0, ttyS2 and ttyS3. I think ttySA0 and ttySA1 are available on the back of the device.
The java part of the software is using /dev/rpg which is a simlink to /dev/sio15 i'm not sure what this is.
