Author Topic: UNI-T UT211B upper amp range not work  (Read 513 times)
Offline Romero77Topic starter
  • Country: bg
« on: March 20, 2024, 01:50:57 pm »
Hello, people!
This is my first post on this beautiful forum. Hope to have a useful time here!
On the problem.. I have UNI-T UT211B clamp meter. After a time, when I needed to measure amperage on 60A DC range I found out that meter don't show reading on display. On 60A AC too. Shows only zeroes.
Only low range 6000/600 mA works.
I don't see any problem on the board, when checked. Here she is:
* IMG_20221004_104725960.jpg (1158.65 kB. 2113x1189 - viewed 32 times.)
The only thing that comes to my mind is corrupt EEPROM.
I will be very, very happy if someone share his dump file of his UT221B!
Have a programmer to do the job. Thank you in advance, people!
  • Country: bg
Re: UNI-T UT211B upper amp range not work
« Reply #1 on: March 23, 2024, 09:33:38 am »
In fact, after self-calibration, it turned out that the DC reads the current at 60A. Only at 60A AC range does not read and at NCV range does not make a sound when touching the power cable.
I found these problems after Duracell battery leak. But it was a little drop on the back of the board.
May be I'm missing something wrong on the board and thing is a EEPROM?
