I've previously unlocked my E4436B to 4GHz and done level calibration by writing file 165 and 207. However one thing annoyed me and that is that the power offset for 4GHz is not applied. To work around this I thought, what about setting the max frequency to 3999999999.999999 Hz instead.
That rendered me an signal generator that boots up, shows boot screen and nothing more.
No GPIB access, is it worth trying RS232?
So now I've picked out the U106 and U107 EEPROMs an trying to decipher them so I can restore unit again. No luck so far.
So in short anyone knows where 165,2 is stored in the actual EEPROMs?
I can try the EEPROM reset procedure but that would require several inserts and ejects of the EEPROMs and probably more EEPROM deciphering.
