Hi again folks.
I'm here because I'm getting trouble connecting the 89600 to the E4406A.
After all the installation I'm stuck with this message:
Cannot find a supported input. Option 300(Hardware Connectivity) is not installed on this system. Inputs will simulate an Agilent VSA E1439 70MHz IF 95Ms/sec ADC.
Of course I've added and successfully identified the instrument in Agilent Connection Expert and I see briefly it in the 89600 loading window just before the message.
My system is WIN XP 32bit SP2, E4406A Hardware is FW A.10.08
If I use SCPI commands via telnet it works fine.
Both TELNET and Socket ports are ON.
I've tried fresh windows installation with 89600 V9.02, V11.21, V12.02
I'm sure that I'm missing something, any help will be greatly appreciated.
Thanks,
0xFEDE
