Author Topic: Agilent E4406A - opt 300 - DIY Cable  (Read 4689 times)
Online bingo600Topic starter
« on: March 22, 2014, 06:45:20 am »
I have a used Agilent E4406A , and would like to install opt-300 (321 Mhz LO out)
"The Option 300 provides a 321.4 MHz output from a rear-panel BNC connector."
There is/was a retrofit kit , but i'd like to make a DIY cable , as the price usually more than doubles when i get it to DK.
http://cp.literature.agilent.com/litweb/pdf/E4406-90104.pdf
My challenge is to find the crimp connector for the "board end" , the other is just a BNC.
I'll use some RG-316 and expect to be able to "crimp it" without a specialized crimp tool.
After searching a bit on the net i found this :
http://g4guo.blogspot.dk/2013/07/agilent-e4406a.html
To connect properly the 321.4 MHz IF output of the A17 assembly I only need a 1.0/2.3 backplane plug connector (DIN 41626).
This kind of product is available at Mouser for less than 10 euros.
But no PN or other hints are given.
In the retrofit pdf Agilent mentions that the connector is locked once it's installed , so i guess there is some kind of lock ring on the connector.
If anyone knows the type of connector Agilent uses , and could come up with an url to a shop , or even better an *bay seller (better due to shipping/minimum order).
It would help me and others a lot.
For now i don't even have any idea if it's a male or female that should be used , i think a female
TIA
/Bingo
Re: Agilent E4406A - opt 300 - DIY Cable
« Reply #1 on: March 22, 2014, 06:56:53 am »
I have added two picts from my initial inspect.
I suppose the connector has to go into the "empty plastic" hole , besides the hardline connector already installed.
/Bingo
Offline picburner
« Reply #2 on: March 22, 2014, 07:26:30 am »
Hello,
the original connector should be like this:
http://www.ebay.com/itm/HARTING-09-14-000-611100-CONTACT-COAXIAL-PIN-50OHM-/171229913143?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item27de192037
but I have used this removing the original black plastic clips and it works well:
http://www.ebay.com/itm/Amphenol-Coaxial-RF-Straight-Cable-Plugs-102-920-06-/321087027852?ssPageName=ADME:L:OC:IT:3160
I lost the automatic graft chance but I do not put and raise the IF card every day!
Regards
Giampiero
« Reply #3 on: March 22, 2014, 10:03:27 am »
Thank you , for the pointers.
Could you explain what you mean about "automatic graft chance" ?
Does it mean that you have to manually connect/disconnect the plug to the A17-Card , if you need to take it out ?
I could live with that
/Bingo
Offline picburner
« Reply #4 on: March 22, 2014, 11:39:09 am »
Yeah, I meant just that.
Giampiero
