Does it actually matter? I'm seeing 68000 series parts to 200MHz or so, which means even the fastest buses can tolerate a couple inches of copper worth of skew or delay.
That is, unless you're using your LA with a pattern generator as a full ICE, where the distance would count for a lot more because you are also injecting signals. If you're just monitoring pins, it shouldn't be of any concern how the delay is unless you're synchronizing to an external source, in which case you just need the offset from it.
