Author Topic: Siglent New SDS800X HD First Bactch Unboxing And Tests And Teardown !  (Read 45340 times)
Offline wysp2023
Re: Siglent New SDS800X HD First Bactch Unboxing And Tests And Teardown !
« Reply #125 on: February 02, 2024, 02:57:00 am »
How to delete all options? Thank you.
Offline wysp2023
« Reply #126 on: February 02, 2024, 02:59:56 am »
« Reply #127 on: February 02, 2024, 04:33:38 am »
Why ?  :-//
If you have an 800X HD it will have pre-western release firmware and a new version is to follow soon.
BTW, you should remove your double post.
Use the Remove icon top right.
Offline MathWizard
« Reply #128 on: February 02, 2024, 01:51:36 pm »
Will they have matte screen coatings too ? So far I've avoided non-matte monitors, I forgot about that whole problem of reflections.
Online 2N3055
  • Country: hr
« Reply #129 on: February 02, 2024, 02:34:48 pm »
Screen is not shiny..
Offline KungFuJosh
  • TEAS is real.
« Reply #130 on: February 02, 2024, 04:22:25 pm »
An easy solution is to put on a matte screen protector in those cases. I usually do that anyway. 🤷
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
Offline worldburger
« Reply #131 on: March 05, 2024, 08:09:22 pm »
How does the 4 ch SDS814X-HD compare to the SDS2104X Plus?
It seems like a great scope or am I missing something...
Offline Antonio90
« Reply #132 on: March 05, 2024, 08:21:44 pm »
SDS2104X-PLUS:
8 bits, 10 bit ERES up to 100MHz
500MHz frontend
2*2GS/s
200 Mpts (per ADC?)
10.1" screen
50 Ohm termination
Auto 1X 10X probe detection.
AWG and LA hardware integrated.
Single Math channel.
No digital filters.
Different architecture (older) and memory management (a bit less responsive on large captures)
SDS800X-HD
12 bit
200MHz frontend.
1*2GS/s
100MPts (824 only)
4 math channels with digital filters.
7" screen (same resolution)
AWG and LA available as external hardware, less integrated amd more expensive.
No 50 Ohm nor probe attenuation factor detection.
No EXT trigger input.
Third of the price.
I think that's mostly it. The Siglent experts will probably correct any mistakes and add relevant info.
The following users thanked this post: Performa01, egonotto, tautech
« Reply #133 on: March 05, 2024, 08:32:08 pm »
Close, quite close but:
2kX+: 2 Math channels with current FW, 4 is coming in the next FW.
200 Mpts mem depth for each ADC < gets halved with 3 or 4 channels active.
Uses SPL2016 LA fitting, all active LA circuitry is in the scope.
800X HD
Sampling rate and mem depth gets divided down by channels in use.
Uses SLA1016 external LA module.
The following users thanked this post: Antonio90
Offline Performa01
  • Country: at
« Reply #134 on: March 06, 2024, 06:05:48 am »
SDS2104X-PLUS:
200 Mpts (per ADC?)
Per ADC!
SDS2104X-PLUS:
No digital filters.
Two math channels. And as I’ve stated multiple times already, there are just not enough resources (FPGA, memory) to support more. Therefore, we’ll never see 4.
Digital filters on the other hand might come with one of the next updates. In fact I’ve already seen them working, yet there is also manual memory management (for providing constant sample rate mode) belonging to that package, and this is a major task with low priority.
The architecture is not different. The SDS2000X Plus was the first instrument with 16-bit internal data processing, which it needed for its 10 bit mode. As one could imagine, this also was the test run for the future (back then) 12-bit scopes in the pipeline.
