Hey guys,
At my job we use a conformal coating called huniseal, which I often need to get under to measure voltages and the like. A lot of people at my work basically solder razorblades unto the end of the probe making them quite large and difficult to work with. I was wondering if you guys knew of the best probes, without modification, that will poke through the coating. Right now I am just using regular fluke probes which mostly work well but require a lot of force to get through.
Thanks for your time,
Srscricket
