Hi RomDump,
I really appreciate your will to help! Your info is very helpful.
It is a PWS4323 and while it was working fine one day I realized that it couldn't provide any current.
Here are some tests I performed:
PWS4323 set to 2V 1A, DC Load set to CC 2A the output of the PWS is 0.11V 0.436A (lower than the limit) !!
PWS4323 set to 27V 1A, DC Load set to CC 2A the output of the PWS is 1.83V 1.62A (higher than the limit) !!
I then probed the output using a scope
![Tektronix PWS 4000 series Schematic/Service manual request](https://www.eevblog.com/forum/index.php?action=dlattach;topic=423938.0;attach=2116829;image)
![Tektronix PWS 4000 series Schematic/Service manual request](https://www.eevblog.com/forum/index.php?action=dlattach;topic=423938.0;attach=2116859;image)
I opened the enclosure, I cleaned the dust (not much) and I started looking for a faulty part on the front end. The diode looks to be fine. While I measured the two capacitors on the binding posts, I didn't notice any strange numbers on ESR or capacitance values but I replaced both capacitors just in case. I reconnected everything and I run a few tests using my load and it seems now that it can give current but there are still some cases which is failing. For example if I set it to 30V 2A or 1A and I switch it on I get a saw tooth output. If I first set it to 10 or 20V and then while it's on go to 30V its working fine. It seems the issue is focused to voltages higher than 20V or something close to 20V. I'm not sure if the capacitor replacement did the difference or it was just random or it is correlated to something else I did without noticing maybe while cleaning? I used a soft brush and compressed air.
Here is another probing I did once I replaced the capacitors and I set the output directly to 30V
![Tektronix PWS 4000 series Schematic/Service manual request](https://www.eevblog.com/forum/index.php?action=dlattach;topic=423938.0;attach=2116835;image)
Another strange thing that I'm not sure if it's caused due to the replaced capacitors is that while I have set the output for example to 20V and PWS measures it as 20V when I measure it with the DC load and cross check it with a DMM it's a bit higher eg 20.3V if I set it to 30V the difference will be even higher eg 30.7V. When I go to low voltages the difference is close to 100mV or less.
