Hello everyone.
Now I was able to install a 1400MHz P-III Tualatin processor. This required editing the BIOS (a lot of attempts before the success).
![](https://b.radikal.ru/b15/1801/15/dcc7d21be8bbt.jpg)
To install it, you needed an adapter PCB.
![](https://a.radikal.ru/a10/1801/41/4fdc349239b7t.jpg)
Of some tests, its performance is higher than the original K6-2-300 in 4 times. It is even ahead of some P4.
![](https://d.radikal.ru/d15/1801/8f/8eb7f3c0b8dbt.jpg)
I also added preventively small radiators to the power converter.
![](https://b.radikal.ru/b14/1801/54/319decc091e7t.jpg)
I was surprised when I measured the frequency of the trigger restart. This amounted to 54 microseconds (18-19 kHz). This is many times higher than the one declared in the datasheet of 2 kHz. In the photo - the impulses start trigger 54845, measured using LeCroy.
![](https://c.radikal.ru/c36/1801/e7/adbabd9a71f6t.jpg)
Indeed, I see a lot of "threads" this device processes in real-time mode.
![](https://a.radikal.ru/a36/1801/73/d1c2097af936t.jpg)
![](https://a.radikal.ru/a25/1801/67/5ea194fa8ac5t.jpg)
