Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Agilent 54831D modernising
« previous
next »
Print
Search
Pages:
Prev
1
11
12
13
14
15
16
All
Go Down
Author
Topic: Agilent 54831D modernising (Read 93560 times)
ARF
Regular Contributor
Re: Agilent 54831D modernising
Reply #375 on:
March 17, 2024, 01:32:51 pm »
OK, if you switch SATA I/Os to the legacy mode, then you can use the original Agilent image with Windows XP. Maybe you should start from this point?
Logged
Bud
Super Contributor
Country:
Reply #376 on:
March 17, 2024, 01:41:43 pm »
A quick search suggests this is a Matlab compiler runtime library and you can get it from a specific version of Matlab, check this link:
https://comp.soft-sys.matlab.narkive.com/OMMJvhdj/mclmcrrtxx-lib
Logged
Shef
Contributor
Country:
Reply #377 on:
March 17, 2024, 02:10:15 pm »
here is the motherboard vp 22
Logged
Shef
Contributor
Country:
Reply #378 on:
March 17, 2024, 02:14:08 pm »
Logged
Shef
Contributor
Country:
Reply #379 on:
March 17, 2024, 02:19:24 pm »
I tried to run the old hard disk image on the new hardware, but it didn’t work! errors and crashes, which is why I asked for a disk image.
Logged
Tony_G
Frequent Contributor
Country:
Checkout my old test gear channel (link in sig)
Reply #380 on:
March 17, 2024, 06:44:00 pm »
I grabbed whatever files were available from the HPAK FTP site for these scopes:
https://1drv.ms/f/s!Amqar8_XQ9Uzj6YhN1xHdM8tQdKMOA
You might want to poke around in the share to see if there is an image you can use for your scope (I have an 54845A) - Another user tried this for his 54832B so maybe it is useful as well:
https://www.eevblog.com/forum/testgear/agilent-54835a-scope-(4-channel-1ghz-4gss)-repair-uphack/msg5199210/#msg5199210
Check out the PDF documents for more information.
TonyG
Last Edit: March 17, 2024, 10:18:02 pm by Tony_G
Logged
TGSoapbox - Test Gear Playlist
Shef
Contributor
Country:
Reply #381 on:
March 17, 2024, 06:54:03 pm »
Thanks a lot! Do I need an image of Windows 7 or Win 10 for lga 775 or lga1155? you do not have ? for 54832b
Logged
Tony_G
Country:
Reply #382 on:
March 17, 2024, 10:23:19 pm »
The images in the share are going to be whatever HPAK originally offered (or enabled for upgrade) - You don't need a license as they're not general purpose images but instead some form of deployment image (e.g. Ghost) that you write to the device.
As I don't have your scope I can only comment on my experience with 54845A - That was a Ghost image that you needed to boot to MS-DOS with a CDRom attached and then run the Ghost tool to push the image to the drive. My scope was Win98 so I never tried the XP images in the share.
Sorry I can't be more helpful - Hopefully someone else on the thread has used the images and can comment (My post here might help outline the steps -
https://www.eevblog.com/forum/testgear/agilent-54835a-scope-(4-channel-1ghz-4gss)-repair-uphack/msg5197191/#msg5197191
Good luck,
TonyG
Logged
Print
Search
Pages:
Prev
1
11
12
13
14
15
16
All
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
