Author Topic: Agilent 54831D modernising  (Read 92115 times)
Offline ARF
Re: Agilent 54831D modernising
« Reply #275 on: March 18, 2023, 08:34:29 pm »
I made an updated version.
- managed to activate Windows by phone.
- update 5.71 already integrated
- options are already integrated.
try.
If all is well, then I will make a disk version, it will be possible to install using 4 СD disks.
Offline bostonman
« Reply #276 on: March 18, 2023, 09:15:29 pm »
Oh wow. I will download and try soon.
For the record, I am happy with what I have, but the missing piece (which isn’t a major concern) is the unallocated disk space.
Offline bostonman
« Reply #277 on: March 19, 2023, 02:59:33 pm »
I forgot how to deal with Ghost.
Do I burn this to a blank CD separately and create it as a bootable or do I boot using something else and then execute Ghost?
Offline ARF
« Reply #278 on: March 19, 2023, 03:02:58 pm »
Did you read my previous post?
Offline bostonman
« Reply #279 on: March 19, 2023, 03:47:40 pm »
Oh, the 4 CD version?
Offline ARF
« Reply #280 on: March 19, 2023, 05:04:11 pm »
I think that now it will be more convenient for you to connect the SSD to a PC with Windows. It's simple and fast, you've done it before.
Read in the message: Reply #273
Offline bostonman
« Reply #281 on: March 20, 2023, 11:39:26 pm »
For whatever reason, I can't get the laptop to recognize the USB CD/DVD ROM, so I tried burning this to a USB.
Unfortunately I forgot the scope isn't capable of booting off the USB.
Most likely I'll stick with the previous method(s), but think I asked and didn't get an answer. The license file has options, but is that ALL the options or do more exist?
If so, how do I activate them?
Offline ARF
« Reply #282 on: March 21, 2023, 12:53:03 am »
Yes, there are only 2 options for recovery, either through a third-party computer or booting from an CD disk on an oscilloscope.
Were you able to restore my last image?
There are other options, but they are useless. The most useful thing there is memory depth, digital signal decoding, jitter.
You can easily add or remove options by editing the license file with notepad.
Offline bostonman
« Reply #283 on: March 21, 2023, 12:58:16 am »
The 4CD image?
That's the one I was referring to. I can't burn it to CDs because my laptop isn't recognizing the external CD/DVD ROM, and the scope doesn't boot from the USB.
I may be able to try the method I did before and use a junk hard drive connected to the IDE secondary.
Offline ARF
« Reply #284 on: March 21, 2023, 01:12:34 am »
Simply plug an SSD into your PC, launch Norton for Windows, and restore. (the same way like for HDD raw copy tool)
I'll make a disk version a little later. I need to make a bootable CD first.
Bootable HDD with DOS and Norton for DOS are also suitable.
« Last Edit: March 21, 2023, 01:15:21 am by ARF »
Offline bostonman
« Reply #285 on: March 28, 2023, 01:00:51 am »
Sorry for the lack of updates, but I've been extremely busy. I plan to test this last file you provided, hopefully this weekend.
Edit: Does a description exist for the additional features? I know you said the ones already in the license file are the important ones, but I'm curious what all the other features are.
« Last Edit: March 28, 2023, 01:14:52 am by bostonman »
Offline ARF
« Reply #286 on: March 30, 2023, 05:57:31 pm »
I don't think anyone has made a complete and detailed description and sorted them by type of supported hardware.
However, if you read the names of the options, it is sometimes clear what they are for.
I wanted to ask. Have you desoldered the resistor on your acquisition board yet? I mean have you already unlocked 1GHz BW?
Offline bostonman
« Reply #287 on: March 31, 2023, 12:41:44 am »
I have removed that resistor.
Offline bostonman
« Reply #288 on: April 02, 2023, 12:35:09 am »
It didn’t work - see attached
Offline ARF
« Reply #289 on: April 02, 2023, 09:57:50 am »
If you let him install the drivers and try again after rebooting?
Second screenshot. - you need to install all the drivers. The interesting thing is that my drivers and yours should match (probably). The only difference is in the configuration resistors on the board.
For convenience, you can hold down the "shift" key while loading Windows - This way you disable autoboot in Windows (scope.exe application) and it will be more convenient for you to install drivers.
« Last Edit: April 02, 2023, 10:12:21 am by ARF »
Offline bostonman
« Reply #290 on: April 02, 2023, 01:31:32 pm »
I tried rebooting, and I got the same errors. It wants to connect to the Internet to search for drivers.
Offline bostonman
« Reply #291 on: April 04, 2023, 01:24:14 am »
I don't mind using the previous method of installing with Paragon, and using the factory partition to reinstall a fresh copy.
The problem between this recent one you made and that: the hard drive will have unallocated (wasted) space. I don't know how to get around this issue.
Offline ekoloski
« Reply #292 on: April 04, 2023, 02:14:09 am »
It's just an NTFS or FAT32 partition that would need to be resized, right?
I'm guessing that you're able to boot from a USB stick into a Linux LiveCD environment? If so, resizing the partition with something like gparted is pretty straightforward, as is removing any partitions you don't need.
Something along the lines of this: https://www.bleepingcomputer.com/tutorials/resizing-adding-partitions-with-gparted-live/
Offline ARF
« Reply #293 on: April 04, 2023, 01:00:38 pm »
Try again to write the image and make the first boot with the "shift" key pressed.
A window will appear with the installation of drivers, click "next, next". Drivers must be built into the system and installed correctly.
If it doesn't, then post it here. Perhaps updating to 5.71 removes unnecessary drivers or something like that.
Offline bostonman
« Reply #294 on: April 05, 2023, 01:47:28 am »
Try which one, the one you made that's a full XP (i.e. four CDs)?
Maybe this will work, I'll have to try. What I've been getting (and on another laptop) is the unallocated partition (after I duplicate a hard drive onto a larger hard drive) can't be touched. The OS partition can't be expanded and I can't seem to mate the OS partition and the unallocated to make one total hard drive.
Offline ARF
« Reply #295 on: April 05, 2023, 09:27:13 pm »
 full XP (i.e. four CDs) - yes
Try it, if it does not work, then I will make for you the same installer from the recovery partition that you have already tested on your scope.
Offline bostonman
« Reply #296 on: April 06, 2023, 12:32:21 am »
I’ll try this weekend - hopefully
Offline bostonman
« Reply #297 on: April 08, 2023, 08:51:41 pm »
I tried your suggestion and it didn’t work.
I don’t necessarily need you to make the previous one (that requires Paragon to install) as a Norton installer. The bigger issue is the unused hard drive space. Gparted treats the XP partition as one and the unused 29GB as a separate partition eliminating me from trying to make one big 32GB partition.
So my needs are more about installing XP so it doesn’t just use a few GB and waste the rest of the hard drive.
Offline ARF
« Reply #298 on: April 08, 2023, 09:05:36 pm »
if I make it as an installer through Norton, then there will be no problem with the partition size. Now you have a partition on the entire disk, right?
Offline bostonman
« Reply #299 on: April 08, 2023, 09:12:51 pm »
Two partitions. One is about 7GB with XP and the other is about 27GB blank.
The Norton one you made prior allowed the entire 32GB to be seen as one drive, and I think the Paragon one may have, I don’t remember now.
